Results 1 to 1 of 1
09-03-2022, 07:25 AM #1
- Sep 2022
- AR
Low idle when brake pressed on C10 LS swap
Hey everyone, I recently put an 6.0 in my 1984 GMC truck. It’s a cam and rockers only and complete rebuild. I used the BP DBC harness and use the 2010 Camaro card style MAF. I had a tune done for it just so it would idle and I could drive it in and out of the shop while I finished getting it road worthy.. my problem is when I step in the brakes the idle goes to about 300 rpm’s. Before we runs down the brake booster path..It does it without the booster connected. It started when I connected the TCC switch.. the switch is working correctly and wired correctly to the switch. Anyone ran across this? I feel like something in the programming is killing the idle once the brake is pressed.. thanks 👍
1986 s10 lq4 swap high idle
By perrone123 in forum Computer & TuningReplies: 0Last Post: 10-16-2021, 08:09 AM -
LS Swap Rough Idle
By Bignon in forum General HelpReplies: 2Last Post: 06-19-2019, 06:43 AM -
Sharpton Pressed on Baltimore, Ferguson, BLM, ... (vid)
By wileyCoyote in forum Political / Debate ForumReplies: 5Last Post: 04-16-2016, 10:56 AM -
brake pad/rotor swap, need help asap!
By Ripper415 in forum General HelpReplies: 45Last Post: 10-24-2013, 09:30 AM -
Question: Idle after cam swap
By slacker4321 in forum General HelpReplies: 5Last Post: 01-26-2009, 05:24 AM
