Thread: wet sand (need reply fast)
08-30-2005, 01:52 PM #1
what size git paper do i use to take off that crap on my headlights of my 98 z , and do i use water when im sanding down the head light?
08-30-2005, 02:00 PM #2Story of My Life!!
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
Man I wouldn't do it unless you have one of those kits. They use like 3000 grit paper and it is a process. You can really screw up your lights even worse.
08-30-2005, 02:03 PM #3
i cleaned up the headlights on my sisters honda with some maguires precleaner, its what i had in the garage but it worked.
08-30-2005, 02:12 PM #4chad_bradGuest
i used 2000 and then polished it up with some meguiers, lloks really good.
08-30-2005, 02:14 PM #5
so just sand with 2000 grit no water just go at it?
08-30-2005, 07:59 PM #6We'll be back...
- THE SWAMP
Wet sand it. Depending on how deep the damage is, you may have to replace the lights. If it looks like little cracks in the plastic and not just a light haze, it's likely too deep to sand out. But give it a try, what do you have to lose, except for a little time?
08-31-2005, 05:53 AM #7Detailing + Design
- Pittsburgh, PA
i'll tell ya now-his lights are just...foggy? no craks at all. Just a foggy/musty kinda covering over all of it-except on the areas that are partially covered by the lip of the hood-those are soooo clear, but it's only like a little 1/4" line on the tops
Originally Posted by GatorSS
09-02-2005, 10:53 PM #8steveo346Guest
always wet sand....when u dry sand the powder builds up on the sand paper and it wont last as long..and as far at the head light lense it will be all full of powder and u wont be able to see which direction the lines of u sanding it are going....u always go side to side motion.....never in a circular motion nor up and down...you'll fudge everything up..trust me i've done mine....
09-03-2005, 08:20 AM #9Junior Member
- houston
PEWTER- 2001 Z28
start with 1500 grit, wetsand. go to 2000 grit, wetsand. go to 2500 grit, wetsand. Apply plastic or metal polish per directions. This should clean 'em up.
09-04-2005, 01:02 PM #10steveo346Guest
those grits are way too fine and wont really make a difference unless its on aluminum....todd
09-05-2005, 07:44 PM #11You really need to start lower.
Originally Posted by todds87ss
400, then 800, then 1000, then higher up if you can still see small scratches.
You need to do this for a long time - it's not a half hour ordeal. Wet sanding is easier. When you have the headlight completely sanded, polish it with something like Meguiars Plastx. Here's mine in the process:
And after:
09-05-2005, 07:48 PM #12
mine are not that bad i think ill start with the 800. it looks like shit when there like that, good design GM
Cant reply
By SandmanWs7 in forum Request and FeedbackReplies: 2Last Post: 01-03-2010, 06:17 PM -
Best Reply
By Soltakr in forum Almost Anything GoesReplies: 61Last Post: 12-22-2007, 07:49 PM -
Can't post reply
By Chubs in forum Request and FeedbackReplies: 1Last Post: 04-02-2007, 06:34 AM -
Not getting reply messages
By Shpoone in forum Request and FeedbackReplies: 1Last Post: 06-20-2006, 10:43 AM
