Thread: interior light problem
05-03-2006, 05:29 AM #1Junior Member
- Jan 2006
- seabrook, tx
silver- 1998 z28 convertable
I have a 98 z28 convertible.
Lately the lights on the mirror and the 2 lights in the back side pannels come on every time I start the car. Then they stay on about 20 minutes after I turn the car off. The dome light switch is not on and the dimmer has no affect on the problem.
Any ideas?
05-03-2006, 07:49 PM #2
That same thing happened to my 1998 camaro..do you have subs in ur car?? I had 2 12's in mine and the base rattled EVERYTHING loose.
05-13-2006, 07:01 PM #3
Sounds like the Retained Accessory Power (RAP) Switch has gone bad or needs adjusting. I had a similar problem on my Formula. I had traded my Firebird in on it, so I knew that when you turned the key off and opened the door, the radio and interior lights should turn off. It seems like the previous owner wanted them to stay on, so he just cut the wire to the switch. (Idiot!) The way I figured out what the problem was is when I had my first passenger and everything shut off when they opened THEIR door. The easiest wat to test this would be to turn off your car and open the PASSENGER side door. If the lights cut off, the driver's side switch is the problem. If not, it's something else. Try this and let us know.
The switch is part of the door latch mechanism and is not available as a separate part. However, the latch alignment is adjustable (slightly) and may not be correctly positioned to trigger the switch. Your 98 should be the same.
1stbird
2001 Firebird Formula
Purchased 8/19/2005
LS1
6 Speed (M6)
Ram Air Hood (Dealer Installed)
Ram Air Box (Dealer Installed)
K&N Air Filter
CAGS Eliminator
DRL Disable
Black on Black
No T-Tops
GM Factory Bra
Pilot Motorsports Shiftknob
Pilot Motorsports Pedal Covers
"My old lady left me and took my Firebird the other day. Damn, I miss that car!"
05-17-2006, 05:03 AM #4Junior Member
- Jan 2006
- seabrook, tx
I triwd the passenger door thing and no luck.
Thanks
Help: interior problem
By 00z28bubba in forum Showcar and DetailingReplies: 7Last Post: 09-09-2008, 05:15 PM -
By u69038 in forum Stereo and ElectronicsReplies: 2Last Post: 06-15-2007, 06:36 PM -
HELP!!! interior LED LIGHT MOD
By 01SOMSS! in forum Appearance SectionReplies: 11Last Post: 06-14-2007, 04:40 PM -
interior light help
By u69038 in forum ConvertibleReplies: 1Last Post: 05-03-2006, 10:04 AM -
Interior problem please help
By Maro99 in forum Appearance SectionReplies: 7Last Post: 03-27-2006, 03:28 PM
