    May 2018
    Starke, FL
    2011 Camaro
    Driver side window will not go all the way up
    Have had my 2011 Camaro with convertible top in storage for last two years, took it out couple of days ago. For some reason the drivers side window now only goes up and down for about the first 2/3 of the way up, then stops dead in tracks. The window goes up effortlessly from bottom up to 2/3 way up, so not like the motor is weak or going bad. The battery was very weak and car had to be jump started. Am wondering if there is a "re-programming" thing that needs to be done. Has anyone had a similar experience and if so, how do you fix it?
    I moved it into the 5th Gen section for more visibility.
    May 2018
    Starke, FL
    2011 Camaro
    Window needs to be "Re-Programmed after battery being dead
    Disconnecting the battery for an extended period of time will require you to reprogram the windows when you connect it back.
    Have you reprogrammed the windows? See page 1-16 of the "OWNERS MANUAL".
    The manual explains how to do this:
    https://www.camaro5.com/forums/attac...1&d=1303241729
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    First, you may need to relearn or re-normalize IF....
    1. The battery has been disconnected or replaced (winter storage may be a problem for some)
    2. The door or motor harness has been disconnected.
    3. Glass is out of alignment
    4. When the door or door window glass has been replaced
    5. When a regulator has been replaced
    METHOD 1: (Use this plan!!!)
    1-A. Open the car door which needs to have the window adjusted. Turn the ignition to the run mode. Do one door at a time !!!
    1-B. In the door jam, release the harness from the door (with a medium screwdriver, pull up the release tab, pull off w/ the palm of your hand, and pull the harness off the door for a minimum of 60 seconds (this is very important as the memory will be lost).
    1-C. Reconnect the door harness and lock the tab back down. Close your car door.
    1-D. The DIC will ask you to lower your door glass.
    1-E KEEP YOUR FINGER ON THE BUTTON FOR 4 TO 5 SECONDS ONCE THE GLASS IS DOWN. ROTATE YOUR FINGER TO THE UP POSITION AND HOLD FOR 4 SECONDS ONCE WINDOW IS AT THE TOP.
    OTHER FUNCTIONS MAY APPEAR IN YOUR DIC BEFORE YOU ARE ASKED TO PROGRAM THE WINDOWS. This is normal
    Window is now reprogrammed, Repeat to the other door glass.
    However, sometimes the door glass regulator does not always relearn on the first attempt. If when you open the door and the door glass does not drop down to the open door position, your window regulator did not relearn or re-normalize...in which case, you are going to need to drop the glass back down, unplug the harness and try again. Yes, it can be picky sometimes and not want to work on the first time.
    If Step 1 did not work, you may attempt this method. Also, if you made glass positioning adjustments, this might also be a fix.
    METHOD 2:
    2-A. Access the under hood fuse box and remove fuse # 26. Wait one minute and reinstall fuse. Close your hood.
    2-B. Get inside car. Close both doors. Start the engine and follow the instructions on the DIC (DRIVER INFORMATION CENTER).
    2-C. The DIC should instruct you to run the window down and up on both sides.
    2-D. Verify that both windows have express up functions and no DIC message exists. If the DIC does not instruct you to operate the window to re-normalize, do the following.
    2-E. With a 2nd person helping, pull the fuse while the window is in the downward motion.
    2-F. The window will stop. Release the window switch.
    2-G. Reinstall the fuse and go back to step 2-B.
    May 2018
    Starke, FL
    2011 Camaro
    That fixed it, drivers side window is now going up and down like it is supposed to.
    Thanks for the help guys!
    Dale
    Junior Member 9T8WS6's Avatar
    Apr 2012
    South East Georgia
    BLACK
    1998 WS6, ASC BUILD #206
    This is interesting.
    All this time and I didn't know windows had to be programed or re-programed.
    I had someone replace both door motors about 7 years ago. He knew how, I didn't. Since that day my windows work backwards.
    Hit the button for up to make the glass go down. Hit down to make glass go up. Same issue on both windows.
    Will this reprogram solve that issue?
    Thanks.
    This T/A WS6 is Factory modified by ASC at the Lachine facility on March 13, 1998 and is identified to be
    ASC build #206.
    We took delivery from Pontiac dealer April 7th, 1998.
    ASC Factory letter provided from them.
    Love of money is the root of all evil.
    Send $19.95 for more information.
    Apr 2012
    South East Georgia
    BLACK
    Quote Originally Posted by 9T8WS6 View Post
    Thanks.
    I guess no one had a suggestion on this... ?
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    If the motors are working in reverse, the first thing that comes to mind is that the polarity may have been reversed. I dont remember if the connectors on the motor and switch are able to be placed 180’ of what they should be.
    Thats my first thought.
    SLP Air Lid/Smooth Bellows
    L76 6.0L block, PRC Ported 243 heads, Texas Speed 228R cam.
    Elite Engineering PCV Oil Catch Can
    SLP Smooth Air Lid and Smooth Belows
    NGK TR55 plugs
    Magnaflow Cat-back
    UMI Front Sway Bar
    Strano Master Cylinder/Firewall brace
    dynoed @ 472 rwhp
    Weight reduction via removal of dead mice
  1. Driver side Window
    By Eric1987 in forum Camaro / SS
    Last Post: 05-04-2009, 06:49 PM
  2. driver side window
    By joejenkinsglass in forum Camaro / SS
    Last Post: 11-16-2008, 07:15 AM
  3. WTB: MAF for LT1 and Driver's side Window Motor
    By efirdj in forum Parts Wanted / Trade
    Last Post: 01-02-2007, 04:21 AM
  4. Driver Side Window????????????
    By 02sunsetorangess in forum Camaro / SS
    Last Post: 11-08-2005, 12:24 PM
  5. driver side window
    By sscrazy in forum General Help
    Last Post: 09-11-2005, 02:08 PM
