Thread: ABS Delete
10-09-2017, 03:55 PM #1
ABS Delete
Here are the results of my recent ABS Delete using the SJM Manufacturing SJM Manufacturing, Inc. (724) 478-5580 kit. Shout out to Steve at SJM for the helpful advice when I called to place my order.
10-10-2017, 02:43 AM #2
Pretty slick setup. Any difference in pedal feel?
10-10-2017, 04:23 AM #3
Solid pedal. Immediately took the car to a COTA track day after installing. I did this for 2 main reasons. Had trouble with ABS false operation constantly after installing 12-bolt Strange rear end -got rid of the ABS problem. After installation of the rear end the brake balance was horrible with the front always locking early -solved that as well. Be warned; the hard lines are really hard and damaged 2 double flare tools in the process [thanks Harbor Freight]. The HF flare tool was the best due to hardened flare anvils. The others were junk.
10-10-2017, 06:02 AM #4Spaz is My Mentor
Same kit I installed 3-4 yrs ago. Only difference is the bracket, did you make it or did it come with the kit? I mounted my PV to the fender well with a spacer.
6.0L Block - Forged 403ci
, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
Keep the egr or delete it?
By Red Z28 in forum External EngineReplies: 22Last Post: 06-24-2011, 01:23 AM -
Question: A/c delete
By 98maro in forum External EngineReplies: 24Last Post: 06-21-2010, 07:13 AM -
EGR & AIR delete
By 96t/a in forum LT1Replies: 10Last Post: 04-10-2008, 04:33 PM -
Delete This
By ss~zoso~ss in forum Political / Debate ForumReplies: 0Last Post: 02-06-2008, 12:53 PM
