Thread: Need help fighting wheel hop
04-29-2006, 06:29 PM #1
I have have had two three fbody's now and have had the same problem with each, wheel hop. I had a 2000 3.8L turbo camaro M5 with 3.73's, Auburn Pro series LSD, BMR LCA's, BMR PHR, BMR TQ arm, and eibach pro kit springs and had violent wheel hop(mainly one jolt when shifting from one gear to anther).
I now have an 02 Z28 w/ BMR Lca's, BMR adj. PHR, 4.10's, and an Auburn series LSD. Befor I put in the gears and LSD I had no wheel hop or jolt upon release of the clutch when racing.
Can you guys offer any help on what I can do to the suspension to eliminate this?
04-29-2006, 07:40 PM #2Junior Member
- Apr 2006
- Memphis
White- 96 Camaro
Lower control arms, panhard rod. Random Tech torque are mounted to cross member between subframe connectors so it pulls on the chassis of the car instead of the transmission. Then when you see how it launches if it squats to bad and you are spinning then air bag in right side spring. THis should elimate all the problems unless you are running low 9's then I have some more suggestions.
04-30-2006, 07:49 AM #3Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
make sure your phb is centered correctly and you LCA bolts are torqued. If you've had the same issue with 2 fbodies and you said you didnt have it before the auburn wouldnt that say something?
04-30-2006, 10:01 AM #4
The wheel hop fix is an ajustable TA.
Try a different pinion angle on your adjustable TA.
If it is set at -2 try it set at zero and if it worse try -3 or -4, etc.
You have to find the 'sweet spot' and it will (should) be gone.
05-01-2006, 02:00 PM #5
no mention of what kind of tires you are using.
05-01-2006, 07:44 PM #6
265/35/18 Fuzion Zri. What if I were to use a stronger stiffer spring on the right rear where the wheel is jumping?
05-08-2006, 05:32 PM #7
w hop
how about a stiffer sway bar (drag bar sphon) imo.
05-21-2006, 05:10 AM #8Junior Member
- Mar 2006
- Cleveland Ohio
Pewter- 99 TransAm
None of the cars had LCA relocation brackets? They are a must if lowered, and I recommend them even for non-lowered cars.
99' T/A M6
433hp 405tq
12.41 @119 on a 2.14 60'
http://www.geocities.com/viper99ta@s...?1151262200545
05-21-2006, 09:51 PM #9Crazy Canuck !
- Jun 2002
- Montreal, CANADA
surprised noone asked which shocks you were using.
Mainly, wheelhop is caused by uncontrollable up-down movement of wheel... shocks are supposed to take care of that.
LCAs gemoetry will help the shock do its job more efficiently, but it's still the shocks job... let me guess... do you have stock shocks ?Eugenio_SS
The Best Defensive Fighting Stance?
By Ed Blown Vert in forum Gun's & AmmoReplies: 0Last Post: 08-19-2011, 07:40 AM -
cage fighting?
By zboy2012 in forum Almost Anything GoesReplies: 110Last Post: 02-17-2011, 01:04 PM -
Me and Ed are fighting
By Sarge in forum Almost Anything GoesReplies: 101Last Post: 08-21-2008, 03:08 PM -
Cop fighting ex-boxer
By Speedy_Gonzales in forum Multimedia SectionReplies: 24Last Post: 11-29-2006, 05:16 PM -
Street Fighting 101
By ThackerSS in forum Almost Anything GoesReplies: 4Last Post: 04-25-2006, 01:30 PM
