Results 1 to 13 of 13
Thread: Head bolts
02-08-2017, 05:43 PM #1
Head bolts
Hello it's been awhile since I posted but I'm trying to buy some arp head bolts for lq4 somewhere in one of my post I believe I've read that there is 2 different sets of head bolts a short set and a set that's all the same.
Sent from my SM-G935P using Tapatalk
02-08-2017, 05:45 PM #2
Head bolts
if the block is 04 or older order short set, if 05 & newer order the long set
02-08-2017, 05:47 PM #3
I thought so I remember you telling me that awhile back just couldn't find it20170208_175008.jpg
The ones circled in red are short the blue are the same sizes
02-09-2017, 07:33 AM #4
SMWS6TA is this where thr shorter bolts go
02-09-2017, 07:49 AM #5
Yes the red are shorter.
Bolts - 6 pt Part #: 134-3609 $ $129
Studs
ARP 6 pt Part #: 234-4110 $290
ARP 12 pt Part #: 234-4316 $306
I have the 12 point studs.
One more thing to remember and the most important. MAKE 100% sure that all head bolt holes are completely dry of any coolant. It only takes a small amount to crack your block.
02-09-2017, 10:24 AM #6
Whats the best way to make sure there's no water in the holes other then turn it upside down
02-09-2017, 11:30 AM #7
I used an air hose to get most of it out. Then tear off some cloth rags into 1x1 squares.
Then using one of these part/tool grabbers with the rag piece I go through each hole until no more liquid damps the rag square.
Not going to lie, it takes a long time to do but worth it.
You could also use a vacuum pump to get most of it out but I still always had to use my trick to ensure no fluid.
02-09-2017, 06:18 PM #8
02-09-2017, 07:05 PM #9
Head bolts
any parts store, hardware, Harbor Frieght etc will carry them.
You could use long q tips or skewers and tape that cloth on too
02-10-2017, 03:12 AM #10
I use a small piece of soft copper tubing on the end of my air hose. 1/4" diameter I think. Put the tubing all the way to the bottom of said hole, place the rag around the tube and cover the hole, then blast the air into the hole. As you blast the air, slowly pull the tubing out of the hole. I've been doing this forever and have had much success with this method. My 1st time I DIDN'T use a rag to cover the hole before I blasted the air......made 1 HELL of a mess. Old Faithfull effect! LOL
1998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
02-10-2017, 05:57 AM #11
It only takes you doing it once to figure out about putting the rag on I may or may not have done that myself....
02-11-2017, 07:40 AM #12
SMWS6TA what head gaskets did you use on your build
02-13-2017, 08:27 AM #13
GM 6.0L LS2 Head Gasket, Multi-Layer Steel Part # 12589227
LT1 head bolts
By bigrondownhiller in forum LT1Replies: 7Last Post: 07-23-2009, 09:49 AM -
Question: Head Bolts!!
By pmolina0436 in forum GTOReplies: 14Last Post: 04-01-2009, 10:44 AM -
LS1 head bolts
By dar54car in forum Internal EngineReplies: 31Last Post: 10-17-2007, 07:54 AM -
F/S: ARP LS1 Hex Head Bolts
By brians98ss in forum Parts For Sale / TradeReplies: 2Last Post: 08-19-2007, 05:59 AM -
f/s AFR 205cc, head gaskets, and head bolts
By slimeball6969 in forum Parts For Sale / TradeReplies: 1Last Post: 08-12-2005, 09:17 PM
