    Manual Mode Engine Braking
    Both our '10 Cadillac and '12 Challenger have the manual mode automatic transmission where you can move the shifter over into another gate and then manually ratchet up and down through the gears. Having been raised on stick cars, it is more of a gimmick than anything else and I rarely use it. I have always wondered though about using manual mode to downshift for engine braking on hill descents. We live in the hills of northern PA and with some of the dumbass drivers we have around here my brakes get a real workout. Yes, brakes are easier and cheaper to replace than a transmission, but I honestly wonder if utilizing manual mode in this fashion is contraindicated?
    Senior Member Naaman's Avatar
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Hang on, let me get my dictionary....
    Okay! Got it. Now I can respond!
    FWIW, I use it on "proper" automatics all the time. Though, it annoys me when a 5-speed transmission limits the driver to selection between D and D3 (no D4 option), such as my wife's car does. Now, I don't know if this actually addresses your question or not (for example, why not just put it in D3/D4 or whatever?). Basically, if I had access to a sequential shift, I'd probably select one gear lower and let it ride down the hill, sparing the brakes as much as possible.
    The owner's manual seems to hint that using the autostick mode will improve transmission life as well as the overall performance of the transmission in situations where frequent shifting is required (look around near page 380). The manual seems to imply that engine braking on a hill is one of the intended functions of the manual mode.
    Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
    Thanks. On old school automatics, I would only downshift manually when towing between OD and D, never to a lower gear than D though. I guess it makes sense that they are designed to handle it, just never felt comfortable using the newer transmissions in that manner.
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Yeah. I guess they got rid of the "OD" terminology because it was confusing (?) I don't get why my wife's 5-speed doesn't let me turn off OD. The 4th gear in that thing is not even 1:1. It's 1.xx:1, with 5th being the OD.
  1. Tranny Shifting Problems In Manual Mode
    By 1SICKT7 in forum Automatic Transmission
    Last Post: 07-25-2014, 07:19 PM
  2. Question: Engine Idle RPM for a 02 Manual
    By kool-aide in forum General Help
    Last Post: 10-29-2009, 02:04 PM
  3. LS1/LS6 Engine Manual
    By LS6TTstroker in forum Internal Engine
    Last Post: 11-03-2007, 08:40 AM
  4. Replies: 0
    Last Post: 09-09-2007, 11:12 AM
  5. 6.0L Engine Rebuilding Manual
    By strokd66 in forum General Help
    Last Post: 08-27-2007, 01:56 PM
