Results 1 to 10 of 10
Thread: Wheel sizes
01-06-2017, 10:53 PM #1Junior Member
- Jan 2017
- Indiana
Wheel sizes
Forgive my ignorance, but I want to put ws6 wheels onto my original trans am (2001) do I need spacers or will they just bolt right on?
01-07-2017, 05:29 AM #2
Welcome to the site! The wheels should bolt right up.
01-11-2017, 03:22 PM #3
WS6 wheels and the stock tire sizes for the WS6 will fit, however GM used a slightly taller rear suspension bumper on the WS6 and SS cars with the 17" wheels. Make very sure your stock suspension bumper is in good shape when you mount the wheels (made of a rubber compound that tends to break down over time). If you notice the tires rubbing under the top of the fenders when you go over bumps, you need a taller bump stop. You can get either a replacement set for a WS6 (expensive) or you can get an aftermarket set (much cheaper) that may require a bit of trimming to get it just right.
Welcome to the site and good luck with your car.ATI Procharger, SFCs, Y-pipe, LM2, BBK Shorty Headers, Corvette N73 Magnesium Wheels, 4th Circle Designs Stripe and Overlay kit
05-22-2017, 10:17 AM #4
Decided to post here instead of starting a new one. -- I want to put 18's all around in place of the 17's that came on my 02 WS6 but I don't want the overall diameter to change. Can I go a little wider than stock and not rub the fenders or do I need to stay with the same width wheel . What tire size would I need to consider to make all this work. I'm hoping someone out there has already done this and can ' steer ' me in the right direction ( pun intended ).
'02 Black RamAir M6--Kooks LTH, Magnaflo, Lowered Eibach springs and Bilstien shocks, Tuned By Frost, K&N & SLP box, Smooth bellows, polished TB, Spohn perf. suspension, shock tower brace. UMI 3point SFC. Front & side splitters w/ canards. American Racing 18" wheels & Mich. Pilot SS titres
'76 LagunaS3 - 355ci , 350 turbo, 3:55's
05-22-2017, 10:24 AM #5Spaz is My Mentor
Contact
98TransAmWs-6
He has 18's on his car.
05-22-2017, 10:48 AM #6Senior Member
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
I have 18×10.5 on all 4 corners of my car. I'm running 295/35/18 tires. I had to shave the bump stops down some in the rear. If I go to 305s like I plan I will probably need to use a hammer on the rear wheel wells to widen them some. Didn't have to do anything in the front.
05-22-2017, 11:44 AM #7
So, did that size of a tire increase the over all diameter of the wheel/tire ?? I don't understand why that would affect the bump-stop. Sorry to sound like a newb on this subject but I want to get it right and don't want to affect the speedo reading or rub the fender edges. also, is there a back spacing I should be concerned with or can it be the same as what's on there already?
05-22-2017, 12:16 PM #8Senior Member
- Apr 2010
- Alabama
The diameter should not change much unless you go with a taller sidewall. Bump stops come into play when you get a tire with a certain width and sidewall height. I've had 275/35/18 and 335/30/18 tires on my car and the overall height of the tire is basically the same as the stock wheels and tires. Different tires are going to very a bit on height even with the same size tire....not much to notice but they may vary a bit.
Sent from my HTC6535LVW using Tapatalk1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
05-22-2017, 12:20 PM #9Senior Member
- Apr 2010
- Alabama
Also in a trans am no no hammering shouldn't be required for fitting 305s. It actually has more to do with the offset of your wheel than anything, the closer to +50 you are the easier time you'll have. It does depend on the tire itself a bit as well since some tire company's tires are wider even in the same size as others. I've fit 335s on my TA no problem, I did remove the bump stop though.
05-22-2017, 12:34 PM #10Spaz is My Mentor
I'll also add you may also need to roll the fenders too with big tires.
Wheel Sizes
By Clint Green in forum Wheels and TiresReplies: 2Last Post: 05-10-2011, 04:01 PM -
question on wheel sizes
By El Toro Loco in forum Wheels and TiresReplies: 6Last Post: 06-21-2009, 03:59 PM -
Black Z06 Wheel sizes?
By rosco924 in forum Wheels and TiresReplies: 25Last Post: 10-10-2007, 10:12 AM -
Wheel sizes
By SSyenko396 in forum General HelpReplies: 6Last Post: 03-23-2007, 07:47 PM -
wheel sizes for 98 Z28
By nabdrill in forum Wheels and TiresReplies: 0Last Post: 03-28-2006, 04:36 PM
