12-02-2016, 09:10 AM #1
"The Mongoose" puts down 447 rwhp and 431 rwtq
Just swapped out cams, and it made a world of difference. The car put down 447 rwhp and 431 rwtq. I will also add that this was with a bone stock LS6 intake and a stock/unported TB.
Mods:
Advanced Induction Dart/RHS 223cc CNC'd heads (11:1 compression)
Custom Cam Motion cam: 232/238 111 LSA
Speed Engineering 1 7/8" headers
Texas Speed True Duals w/ SLP Loudmouth 1 resonators
Accel 44lb/hr injectors
LS6 intake and unported TB
I'm very happy with those numbers. The car feels so much stronger than it did with the old cam (Tick SNS Torque Max Stage 2 "227/235 110 LSA"). The new cam also pulls so much further in the RPM band than the old cam, as the old cam fell of at 5,800 RPM's. I will be adding a FAST 90mm intake/92mm TB here soon. I will port the FAST 90mm intake out to 92mm and port match the runners to the heads. Here is the dyno graph.
12-03-2016, 02:41 AM #2
Nice!
12-07-2016, 03:36 PM #3
Nice numbers.
12-08-2016, 01:32 AM #4
Right on. I'm hoping to push somewhere around there when I'm "done" with mine. I'm also thinking about doing a FAST 92mm.
Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
12-08-2016, 09:44 AM #5
I just purchased a used FAST 90mm intake today. I will port out the inlet to 92mm and then port the runners. I'm also going to paint it. Not sure if I want to paint it black and do the lettering in pewter, or paint the intake pewter and do the lettering in black.
"The Mongoose" - 447rwhp and 431rwtq
12-09-2016, 09:49 AM #6Spaz is My Mentor
Paint it whatever way you like. I did.
Black for the intake and used Navy Blue/Red for the letteringhttp://www.ls1.com/forums/f7/my-6-liter-build-174257/
6.0L Block - Forged 403ci
, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
what my rwhp and rwtq at?
By FMR_TransAm in forum Dyno InformationReplies: 5Last Post: 04-17-2012, 04:33 AM -
317 rwhp/ 316 rwtq
By bene in forum Dyno InformationReplies: 24Last Post: 05-29-2008, 09:22 AM -
How Much RWHP and RWTQ?
By WS6ICK in forum Firebird / WS6Replies: 5Last Post: 04-21-2007, 03:02 PM -
does the member "mongoose" or somethng like that still post here?
By Ice Spiral in forum Almost Anything GoesReplies: 0Last Post: 04-22-2006, 04:34 PM -
most rwhp/rwtq with p1sc?
By OneBadZ in forum Forced InductionReplies: 1Last Post: 10-23-2005, 11:28 PM
