Results 1 to 2 of 2
    Oct 2016
    Chicago
    Nissan 240SX
    LS1 Swapped 240SX Bank 2 40% Extra Fuel issue
    Hey everyone! I have a 1995 Nissan 240SX swapped with a LS1/T56 from a 2000 Camaro SS. The mods done on the engine is a Texas Speed 228R, PAC Valve Springs and Comp Cams Hardened Push Rods, and a Wiring Specialties LS1 to S14 240SX harness. When the engine was swapped it was initially tuned with HPTuners just to move in and around of the garage because it was not road ready at the time. I eventually ran into low oil pressure problems (faulty oil pump, oil pump pickup tube sitting too low in sump and o-ring not seating correctly into oil pump) and sent it to a shop to have that sorted out, along with a few other odds and ends like custom brackets and such. With the oil pressure issues sorted out, it got sent out to tuning and they ran into an issue where the Bank 2 O2 was not reading correctly (Bosch O2), they replaced the O2 and it still wasn't reading correct values so it was dumping 40% extra fuel into Bank 2. They believe there is an issue with the continuity in the wiring for Bank 2 O2, coil packs, or injectors.
    Any and all input is appreciated!
    Oct 2016
    Rossford
    Have they put a scanner on it to verify that what's being sent to the pcm is In fact I correct? They should be able to use the scanner through the OBDII port to see that it's 40% high by comparing it to the scanner attached directly to the O2 sensor, not getting a reading through the PCM. In other words they should be two different readings. Have they done that?
    Sent from my iPhone using Tapatalk
  1. New pics of my LS swapped 240SX
    By OutToWinPAHC in forum Member's Rides
    Last Post: 11-18-2010, 05:29 AM
  2. LT1 to LS2 Fuel Issue
    By MaxPlusTen in forum General Help
    Last Post: 03-10-2010, 05:25 PM
  3. Help, Fuel Trim on passenger side Bank
    By Brutis in forum Computer & Tuning
    Last Post: 07-20-2009, 11:32 AM
  4. Extra screw after fuel tank R&R.
    By 2002Zapper in forum General Help
    Last Post: 02-08-2008, 04:35 PM
  5. anyone have an extra fuel pump laying around?
    By 0rion in forum General Help
    Last Post: 04-15-2006, 04:28 PM
