    Sep 2016
    louisiana
    Knocking after intalling new pcv hose and opsu
    i took the intake manifold out and replaced all the gaskets and cleaned the valley carefully " i did stuff rags in the intake ports to ensure nothing falls in" and i replaced my old leaking oil pressure sending unit that by the way cracked in half lol and replaced the pcv hose . and after everything was said and done and put back together i let the car idle relearn and about 5 or 10 minutes into it it just died so i started it back up and it did start but there is a random knocking noise now and i expecting the worse outcome . i love my car and do not want to get rid of it it is my dream car .
    You did remember to account for all nuts, bolts, tools and rags, right?
    Is there any codes popping?
    I ask about the codes because the 1st time I had to take my intake off one of my knock sensor wire harness was pushed into the cylinder and burnt it in 2. Now I take a piece of masking tape and use it to hold down the harness.
    Sep 2016
    louisiana
    turned out to be a spun rod so im in the process of getting a new ls1 motor hopefully in a month ill have the pheonix rise from the ashes lmao
    Spun rods are easy to fix unless you ate the crank. A good machine shop can resize and buff out the crank & rods. Far cheaper than a new motor.
  1. broke my OPSU
    By 1998 T/A in forum General Help
    Last Post: 11-12-2014, 01:28 PM
  2. part # for OPSU?
    By freddy_caprice in forum External Engine
    Last Post: 07-10-2011, 12:03 PM
  3. Help: top end knocking
    By 2000dreambird in forum Internal Engine
    Last Post: 02-23-2011, 02:07 PM
  4. Help: Bad knocking
    By jsherman in forum General Help
    Last Post: 10-06-2008, 04:14 PM
  5. Intalling Electric Cutout During Winter?
    By NiteRiderWs6 in forum External Engine
    Last Post: 02-02-2007, 06:12 AM
