Results 1 to 3 of 3
Thread: Transmission crossmember help
08-04-2016, 06:50 PM #1
I have an 01 Z28 with a stock LS1 and 6 speed tranny. I also have some suspension upgrades. I ran over something awhile back, which I later found was a large brick. It hit my Y-pipe and dented the hell out of it but it also smacked my transmission crossmember. Looks like a superhero punched it upward and it's also damaged....was wondering why my shifter seemed a little bit higher. Anyways, doing a clutch change soon and since I'm taking out the tranny, I was thinking replecing the crossmember with one from BMR. My questionS are:
Is it a direct swap?
Is it used in conjunction with anything else?
Which one?...the TH350, TH400 or 4L80e?
Why is it called a "conversion?"
Thanks2001 Chevrolet Camaro Z28, M6, Eibach Pro-kit, BMR STB, BMR Adj-PHB, BMR RB's, BMR SB's, BMR Adj-TA, KYB Adj-shocks, K&N, SLP LM, SLP Y-Pipe, SLP Intake, Predator Custom Tuned...
Treat her well and she'll put a smile on your face every time you get on her!
08-04-2016, 08:53 PM #2Spaz is My Mentor
Try UMI Performance.
I have their Crossmember for T56 and their Torque Arm.
Pretty stout piece.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
6.0L Block - Forged 403ci
, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
08-06-2016, 05:08 AM #3
+1 on UMI. Well built, perfect fit and look great.
By ntymd8r in forum Manual TransmissionReplies: 5Last Post: 09-27-2016, 09:13 PM -
Question: Transmission Crossmember???
By el-camino-bill in forum General HelpReplies: 0Last Post: 10-24-2010, 10:50 AM -
t56 crossmember
By 98 Trans-am in forum Parts Wanted / TradeReplies: 0Last Post: 08-10-2010, 11:37 AM -
Lovells Crossmember Bushings
By CamaroFan71 in forum GTOReplies: 2Last Post: 03-25-2010, 09:24 AM -
Tubular Front Crossmember...
By Fury_786 in forum Camaro / SSReplies: 20Last Post: 11-20-2009, 01:43 PM
