Results 1 to 3 of 3
Thread: Anyone running KW V3 coilovers?
05-08-2016, 06:17 PM #1
I've got over 60K on my Koni's and with the Strano springs, my ride is a little lower than is practical for my driveway (the curbs here in AZ are "soft" but its kind of a climb to get into the driveway). For now I just live with it, but it would be nice to raise the ride height back up a bit, and retain a high level of performance.
As for my goals with the car, they have always been to build a fast, smooth performing vehicle that can be a commuter, a road trip cruiser, and a canyon carver. As she sits, the car is pretty well close to exactly what I want it to be, but I wouldn't mind a bit more ground clearance (especially if headers are in its future) and a strong, well designed suspension. Might be a year or more from now, but I've been thinking about it and was curious if anyone is familiar with the set up.
Anyone ever tried the KWs or ridden in a car that has them?
05-20-2016, 03:30 PM #2Junior Member
- May 2016
- NW Houston
Do you have the snap rings on the koni's set to the highest ride height? If not that's where I would start.
Sent from the future via a wifi time portal.
05-21-2016, 06:55 AM #3
Hey, thanks for the tip. And welcome!
I'm honestly thinking that the shocks are on their way out: they have over 60K on them now. But instead of spending the amount to replace all 4 corners, I'm thinking I'd just get coil overs for the next phase. Though, as I said, It would probably be in the mid-term future, not immediate.Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
qa1 coilovers
By fastZ in forum Suspension and HandlingReplies: 3Last Post: 05-16-2010, 06:20 AM -
will 96 coilovers fit a 98
By bossho in forum Suspension and HandlingReplies: 0Last Post: 10-02-2009, 02:45 PM -
adjustable coilovers
By Nasty TA in forum Parts For Sale / TradeReplies: 5Last Post: 02-02-2009, 11:43 AM -
The QA1 Generation F coilovers
By austinWS6 in forum Suspension and HandlingReplies: 0Last Post: 01-03-2007, 03:40 PM -
coilovers
By johuckabee in forum Suspension and HandlingReplies: 6Last Post: 04-11-2006, 02:58 PM
