    Apr 2016
    Fort Branch, Indiana
    Mystic Teal
    1998 Camaro z28
    Talking Did I get a good deal?
    I recently bought my Mystic Teal 1998 Camaro ls1 a few weeks back, its automatic, grey leather, all power, t-tops... everything is stock on car, even the exhaust lol. it has 113,xxx miles and bought for $4,500. Did I do good?
    Not bad and congratulations, hope it all goes well.
    Is this your 1st LSx/f body car?
    We have a lot of members here that are very knowledgeable on common issues and other stuff. Ask away if you have questions.
    Apr 2016
    Mystic Teal
    1998 Camaro z28
    yes this is my first fbody.
    Here is some of the common issues that pop up on f-bodies:
    Passenger Window - It dies quicker then the drivers side. Reason is GM ran the + wire to the drivers side and then to the passenger side, by the time it gets there it is under current. There is a cheap ($38) fix from a company called Autotrix. Well worth the $$$, Did mine 5 yrs ago and still have both motors running strong.
    Body flex - When you can, invest in 2pt or 3 pt Subframe Connectors. Our cars are uni-bodies, meaning there is no solid frame from front to rear like most cars, the frame is connected to the body for the front & middle but the compartment area has none. SFC's tie the front & rear together and prevent flexing. There are bolt in and weld in, with bolt in you can always go back and weld in.
    98LS1 - oil pump is weak in it, trust me I know... It will still work fine for daily driving and cruising around but if you are wanting to track it I highly suggest getting either a LS6 oil pump or a Melling 10295 oil pump. You'll see a Melling 10296 but for stock & mild bolt on's stay with the other 2.
    Tune - Check out TunebyFrost.com - he has by far the best mail order tune, even for stock and mild bolt on's like headers.
    Rear - if there is a great weakness on these cars it's the rear 10 bolt. If you're a manual car stay away from Drag Radials or slicks.
    Here is some Tech stickies on other issues and problems that members have come up with fixes.
    http://www.ls1.com/forums/f6/technic...tickies-79083/
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Welcome to the club. Fellow Hoosier here.
    Apr 2016
    Tampa Bay
    Seems like a pretty fair deal to me
  1. Is this a Good Deal?
    By 2001ws6 in forum External Engine
    Last Post: 12-08-2008, 04:15 PM
  2. Question: 99 SS, Is this a good deal?
    By 82blayser in forum Camaro / SS
    Last Post: 03-03-2008, 06:34 AM
  3. Anyone else see this as a good deal?
    By allbaugh_04 in forum Camaro / SS
    Last Post: 08-18-2007, 10:59 PM
  4. Good or bad Deal?
    By SStriker in forum Camaro / SS
    Last Post: 04-10-2007, 05:46 PM
  5. Good deal or what
    By ss~zoso~ss in forum Wheels and Tires
    Last Post: 12-21-2005, 05:37 PM
Tags for this Thread
