Results 1 to 20 of 31
03-23-2016, 04:12 PM #1Senior Member
- Apr 2010
- Alabama
Need a driveshaft...what are you guys running
So I need an aftermarket drive shaft that will handle my power what are you guys running and where did you get it from? No clue my actual power but I'd imagine up there no more than 700 at the engine.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
03-23-2016, 07:19 PM #2
I have the 3.5" aluminum PST driveshaft which is rated for 1200. It's a very nice piece. Jeff is running it too.
I got mine from Bob at EPP when he was selling parts. Can't recall what I paid for it, but it's worth the coin. I want to say - $425ish.
They have a carbon fiber piece which is even nicer, but more expensive of course.Boost gets you laid, unless your name is Jon.
03-23-2016, 08:05 PM #3Senior Member
- Apr 2010
- Alabama
I'll check those out thanks.
03-25-2016, 04:34 AM #4
03-25-2016, 04:41 AM #5Senior Member
- Apr 2010
- Alabama
They don't do stock length ones do they? I need a stock length one because I'm doing an 8.8 rear. All I found is strange that does stock length in the 3.5".
03-25-2016, 04:44 AM #6Senior Member
- Apr 2010
- Alabama
Nvm I found that PST does make them stock length.
03-25-2016, 06:27 AM #7Senior Member
- Apr 2010
- Alabama
Okay so I decided on the drive shaft I'm getting. It's a strange engineering 3.5" chromoly with chromoly solid 1350 joints and chromoly spicer yoke for the 10 bolt.
Once I get my 8.8 built I will be getting this flange to convert it to a 1350
03-25-2016, 07:54 AM #8
PST shaft is larger diameter than stock, maybe 4" instead of 3.5". As far as I recall they build custom lengths - I needed mine around 5/8" shorter than stock.
03-25-2016, 07:40 PM #9
Yours appears to be of exactly the same (if not slightly smaller) than the stock one next to it.
Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
03-26-2016, 03:59 AM #10
^^ Me?
If so, look where the shaft joins to the mounting flange -- you'll see the marked diameter difference. I even had to tweak my driveshaft safety loop because of how large the PST shaft is.
03-26-2016, 01:51 PM #11
I'm fairly certain it's 3.5" diameter, Jeff. Perhaps the OEM is smaller than 3.5" then.
03-26-2016, 01:55 PM #12Senior Member
- Apr 2010
- Alabama
How do they measure it I have my oem off and I can verify lol.
03-26-2016, 02:37 PM #13
You can try a measuring tape and the hairy eyeball. I think stock is 3.5" and the PST is 4"... but it has been a number of years since I installed ours.
03-27-2016, 10:26 AM #14
I found my receipt. It's 3.5" × 45-1/4".
I paid $400 for it.
03-29-2016, 03:15 AM #15
Heck, now I am going to have to go look at mine again. Is the stock shaft only 3"?
03-29-2016, 04:24 AM #16
I have one in my basement. I'll measure it this afternoon.
03-29-2016, 12:49 PM #17
OEM measures 3".
03-29-2016, 01:06 PM #18Spaz is My Mentor
It also depends on if you have an aluminum or steel drive shaft.
98's have an aluminum and I believe it's 3.5 to 4"
The 02 steel drive shaft I have in a corner is 3"
03-29-2016, 01:27 PM #19
My drive shaft from 2002 is not steel, it's aluminum. I just researched it and what I found was that all driveshafts from 1998 to 2002 are aluminum and 3". V6 models had steel driveshafts as did older LT1 models. V6 models were 2 piece. Not sure on the accuracy of this, but mine is definitely AL.
03-29-2016, 01:33 PM #20Spaz is My Mentor
Interesting....
What tires are you guys running?
By grouch0jr in forum Wheels and TiresReplies: 13Last Post: 07-03-2012, 07:21 AM -
Running rough if running at all help
By ichliebecamaro in forum LT1Replies: 3Last Post: 01-25-2010, 10:54 AM -
Are you guys cool with Palin running the country?
By Murder after Midnight in forum Almost Anything GoesReplies: 115Last Post: 09-22-2008, 06:00 AM -
heads/cam guys running dumps.....
By 0rion in forum External EngineReplies: 13Last Post: 08-17-2007, 03:47 PM -
What do you guys think about running the 4.11 yukon gears
By 1959ls1 in forum DrivetrainReplies: 0Last Post: 07-05-2006, 09:11 PM
