Results 1 to 14 of 14
    Junior Member k dog 33's Avatar
    Aug 2008
    Plainfield ,illinois
    2000 Ws6 T/A
    Need a good speed shop for repairs to my Ws6
    I need help finding a shop to install long tube headers,catback exhaust,plugs/ wires and a tune. I'm in the Plainfield, il area. Any help would be greatly appreciated. ..thanks!!!
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    Why not do it yourself and save a ton of money? It's not that hard it just takes some time.
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
    Aug 2008
    2000 Ws6 T/A
    That ride is Sikkk!!!! I don't have the equipment and I'm not good at working on cars. I've failed the emissions and just want it done right.
    Apr 2010
    Alabama
    Black/ Silver
    Lol thanks I've put a lot into it. Ah it's going to be expensive. It takes basic tools and a Jack and Jack stands.
    Aug 2008
    2000 Ws6 T/A
    Thanks...I will go invest in some equipment and give it a try.
    Apr 2010
    Alabama
    Black/ Silver
    Make sure you get a floor Jack and stands that can go up around 20+ inches. It will make it a whole lot easier.
    Aug 2008
    2000 Ws6 T/A
    Cool...I'm taking notes...lol. thanks again
    Apr 2010
    Alabama
    Black/ Silver
    There is a guide on how to do it on ls1howto.com
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Go to Speed Inc. if you ever end up needing a shop for something.
    You also need a second person to hold the header as you get a bolt started. Be very careful on the drivers side header. Near #1 plug just behind the power steering pump/reservoir is the coolant temp sensor that goes into the head. They are a usual victim of header installs because you don't remove it unless you want to drain your coolant.
    Apr 2010
    Alabama
    Black/ Silver
    I didn't need a second person but it would be easier.
    Greensboro, NC
    2002 Trans Am WS6 M6
    Yup ask me how I know this is true.
    the coolant sensor? Yeah mark me down under that one too.....
    Greensboro, NC
    Yup
  1. Question: Good establishment/speed shop in Fresno area?
    By Walkabout in forum Western Members
    Last Post: 04-28-2009, 09:53 AM
  2. 6 speed rebuild/repairs d&d performance
    By cjtz28 in forum Manual Transmission
    Last Post: 11-10-2008, 11:42 AM
  3. Replies: 6
    Last Post: 09-14-2007, 10:06 PM
  4. Speed Shop
    By splitfinger09 in forum Western Members
    Last Post: 08-22-2007, 01:41 PM
