Results 1 to 13 of 13
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    Performance throttle body opinions?
    Does anyone have any opinions on performance throttle bodies that will fit a cable driven (Not drive by wire) LS with an LS6 intake?
    I plan on getting at tune for my mods in my sig', figure might as well add a simple TB to boot.
    Still running the stocker on our car. From everything I have read, Nick Williams seems to be the way to go. Not sure that they offer one for a stock manifold though.
    Senior Member Naaman's Avatar
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    I'm not seeing your sig...?
    I got mine from Shaner, but not sure if he's still doing 'em... I like it, though.
    Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
    Sep 2010
    Bel Air, Maryland
    Quote Originally Posted by Naaman View Post
    What the hell? Why does my sig show up in some posts, and not others?
    SLP lid and belows, Kooks emissions lt headers and catted y pipe, Magnaflow cat back, Walbrough 255 fuel pump.
    Greensboro, NC
    2002 Trans Am WS6 M6
    Unless your going to upgrade to a larger intake such a fast or msd your better off just porting the stock ls6 intake and your throttle body. The Nick Williams piece is so big your ls6 intake won't make it worth the money.
    Sep 2010
    Bel Air, Maryland
    I tried to help narrow it down by specifying that it would go on an LS6 intake.
    I know it wont be a mega power jump but I know my air intake is less restrictive than factory, and my exhaust is less restrictive as well, so I want to help fatten ip what is under the curve.
    I really didnt think I would go much bigger, if at all but knew there have been 78mm's offered in the market. I just don't know if porting the stock TB is something the average speed shop would be proficient at, or if a supplier, or even which supplier, is the better choice.
    If I remember right, there is some work that can be done to make the throttle blade fully open (90'), that the factory setup doesn't do as well.
    ^^ All you do is file back the throttle stop to ensure that the blade is parallel to the bore at WOT. I had to remove a bit of material from our TB to accomplish this. Just be careful not to over do it.
    Sep 2010
    Bel Air, Maryland
    As a follow up to what you have said, does the TPS need any recalibration when that happens, or does the program have that ohmage mapped out?
    SLP Air Lid/Smooth Bellows
    L76 6.0L block, PRC Ported 243 heads, Texas Speed 228R cam.
    Elite Engineering PCV Oil Catch Can
    SLP Smooth Air Lid and Smooth Belows
    NGK TR55 plugs
    Magnaflow Cat-back
    UMI Front Sway Bar
    Strano Master Cylinder/Firewall brace
    dynoed @ 472 rwhp
    Weight reduction via removal of dead mice
    Nope. Just be careful not to get any filings in the T/B if you do it off the car.
    Member 1998 T/A's Avatar
    Aug 2008
    Huron Ohio
    2000 WS6 Trans AM
    I did a FAST 92 with a polished Nick Williams 92...I think it all cost me 1100 dollars but definitely worth it in my opinion. I will probably send the intake off to get ported when I do heads and cam in a few months
    98' Trans AM RIP
    00' WS6/Black/Pacesetter LT's/Magnaflow Exhaust/SLP lid/Nick Williams 92mm TB/FAST 92 Intake/BMR Strut Tower Brace/BMR Rear LCA's/BMR Panhard Bar
    Sep 2010
    Bel Air, Maryland
    Quote Originally Posted by 1998 T/A View Post
    If I should ever realise my dream and find an inexpensive LS3 or LS7 short block (aluminum, not the iron truck 6.0's bored out, or the LS7 destroked to 3.66) and what I need to make it go, I MIGHT spend $1,100 on an intake and TB. I am nowhere need that much flow ATM, or the near future.
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    If I ever got my hands on an LS7, I'd also need to find a 1970 A-Body and a T56 Magnum to install it in.
    Sep 2010
    Bel Air, Maryland
    I've seen new, bare blocks offered for abou$2,500. I figure I would need about a $6,500 budget or so for the whole "destroker" but I am not quite there.
  1. S2 performance or Newera for ported throttle body
    By Dreamnz28 in forum External Engine
    Last Post: 01-06-2013, 07:17 PM
  2. Portz Speed and Performance Throttle Body and Maf Ends?
    By My00Z28 in forum External Engine
    Last Post: 09-18-2011, 04:30 PM
  3. S3 Throttle Body from S2 Performance
    By Naaman in forum Parts Review
    Last Post: 05-26-2011, 06:29 PM
  4. opinions on performance
    By scottydont901 in forum Camaro / SS
    Last Post: 08-17-2008, 04:26 PM
  5. Throttle body for GM Performance LSX block?
    By redss in forum General Help
    Last Post: 11-16-2007, 06:25 PM
