    New Jersey
    2000 WS6 Trans Am
    Need new rear hatch struts
    Hello everyone. I have a 2000 WS6 Trans Am and the rear hatch struts are worn out. You have to hold the hatch open with your hand as it won't stay open on its own anymore. I'm looking to get new struts for it but am unsure how to proceed. I see quite a few used OEM struts on e-bay, but I am hesitant to purchase because who knows how much life they have left in them. I also see new manufacture struts that are supposed to be "stronger than factory". Here is an example of what I am looking at: 1993 2002 Camaro Firebird Trans Am Trunk Lid Rear Hatch Lift Supports 93 02 | eBay I don't need anything fancy, just some good solid struts to hold the hatch open. Any advice or opinions on how I should proceed would be greatly appreciated! Thanks in advance!
    Senior Member kingls1's Avatar
    Apr 2011
    Johnstown,PA
    1999 Trans-Am, 2012 Sonic
    I needed new hood struts grabbed some from ebay and turned out only needed one. Only one of the two was bad not enough to hold it up. So far so good and now I have a spare. Pick them up from a trusted seller you should be fine
    99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
    Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
    Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
    Wish list.
    Coil overs, Heads & Cam
    Not sure the exact part number, but at Autozone new hatch struts range from $24 to $38. I would just hit a parts store and be done with it.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    The auto part store replacement worked great for me.
    024mula 024mula's Avatar
    Dec 2010
    Ohio
    '02 Firebird Formula
    Please go to a auto parts store and get the correct part needed.
    But whatever you do, please don't use a broom stick.
    2002 Firebird Formula - 5.7 Liter - "Last of the Breed"
    I keep an old adjustable shower curtain rod with rubber end caps in my shop just in case someone brings me a vehicle with non-functioning struts to work on.
  1. 99z28 hatch back struts
    By StoreKeeper99Z28 in forum Western Members
    Last Post: 05-17-2015, 09:39 AM
  2. Help: '01 Ram Air TA Rear Hatch Lift Strut Mount loose in Hatch
    By NAVYGSE1 in forum General Help
    Last Post: 12-20-2011, 01:07 PM
  3. Adj. Front And Rear Struts/shocks For 02 T/a
    By RAMAIR02 in forum Parts Wanted / Trade
    Last Post: 08-04-2008, 05:18 AM
  4. Front Struts/ Rear Shocks?
    By ssxcytmnt in forum General Help
    Last Post: 11-11-2007, 08:35 PM
  5. installing rear lowerings springs and struts
    By adham in forum Suspension and Handling
    Last Post: 08-04-2007, 06:34 AM
