    Feb 2016
    san tan valley
    motor wont line up with mounts
    Hey guys, im putting an ls2 into my 2002 camaro z28 and im having trouble getting the motor to line up with the motor mounts. had oem mounts, then i bought after market mounts thinking it would work but still having problems. i can get one side in but the not the other. any help is appreciated, thanks
    I had a heck of a time with ours when I installed poly mounts. Basically ended up using a large pry bar to leverage it into place in order to install the bolts that attach the driver side mounting plate to the block.
    If you loosen but not remove the bolts on the passenger side pedestal to the k member it will make it easier to install.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    On top of what those guys said, I always put the bolts for the frame in first, leaving them loose, then line the motor up, using a pry bar or jack to get the motor bolts in.
    "Some people live for the rules..... I live for exceptions" N. Hexum
  1. Energy Suspension Motor mounts or prothane mounts
    By Justin23454 in forum External Engine
    Last Post: 11-14-2010, 09:31 AM
  2. Why wont my prothane mounts line up!!!
    By 01ws6er in forum External Engine
    Last Post: 02-07-2009, 08:20 PM
  3. UMI SFC'S 3 point center wont line up?
    By Dr.Crash in forum Suspension and Handling
    Last Post: 01-22-2009, 10:27 AM
  4. LCAs wont line up
    By 6-Speeder in forum Suspension and Handling
    Last Post: 12-31-2007, 09:27 PM
  5. Motor Mounts...HELP!
    By OneFine99TA in forum Western Members
    Last Post: 10-12-2005, 05:35 PM
