Thread: Morel Lifters and LS7 Lifters
02-04-2016, 10:03 AM #1Impounded
- Feb 2016
- Australia
Blue- VE SS-V ute
Hey guys,
Doing a bit of work to my car at the moment and wanted some advice. I have a set of Morel street series 5290 tie bar lifters in the car at the moment. One of them has some mild pitting on the roller. The cam is out and has been taken to a cam specialist to check it and it's all in good condition.
Now, I've been advised to change the lifters to LS7 lifters.
I don't know much about these LS motors, this is the first one I've worked on. My question is this:
Are all LS lifters the same height/profile? If I swap out my Morel Link Bar lifters in favour of LS7 lifters, how do I know that the seat for the pushrod isn't higher or lower on the LS7 lifter than on the Morel Lifter? If it's not the same height, I'll either overextend the pushrod/rocker/valve or the valves won't open as far as they do now, so are the LS lifters all a universal length?
The engine is running this gear:
6.0L L98 motor
Cam: 242/245 620 Lift
Pushrods: Trend 210 7.350 .080
PAC dual valve springs
Any advice is greatly appreciated!
02-04-2016, 11:23 AM #2
I can't answer you question precisely, but I can offer what I do know.
I have some worked heads that were milled down a tad (enough that the compression ratio increased to the point that I needed different spark plugs). My car is also running on a mild cam (I think it's a stock Silverado cam, but I'd have to ask). It has LS7 lifters, running with the push rods that came with the heads (799, stage 1 machining: ported, 4-angle valve job, etc).Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
02-04-2016, 01:11 PM #3Spaz is My Mentor
I'm running LS7 lifters in my 403 and no issues so far. LS7 lifters are now the standard lifter for all LS1,2,6 and LQ4/9 & 5.3's. I can't say about the LS3's.
Only way to know for sure if you are good on the push rod length is to get a checker and measure.
Here's a thread on how to do it.
http://www.ls1.com/forums/f7/how-mea...0/#post2876821http://www.ls1.com/forums/f7/my-6-liter-build-174257/
6.0L Block - Forged 403ci
, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
02-04-2016, 01:14 PM #4Spaz is My Mentor
One more question....if you're using Morel Link Bar lifters why not stay with them? Going to LS7 would be a step back IMHO.
02-04-2016, 08:31 PM #5Senior Member
- Apr 2010
- Alabama
Fuck no don't swap the link bar morels for the ls7 lifters. The morels are superior in every way to the ls7s. I have morel 5206 link bar lifters in my engine, there is no way I would trust ls7s in my motor but then again it is a 421 ci lq9 that is max effort build but still. Besides $1000+ lifters there really isn't anything else better than Morels out there. I would stick with them but just so you know any time you change the lifters you need to check for pushrod length because different lifters require different pushrod lengths because of the preload they require.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
Comp Cam Lifters or ls7 lifters?
By Frankthetank in forum Internal EngineReplies: 6Last Post: 06-03-2007, 01:26 PM -
Take a look at these lifters...
By 408WS6 in forum Internal EngineReplies: 3Last Post: 05-07-2007, 07:57 PM -
Sub box w/ JL subs, amp, 7.3" pushrods, Morel lifters - Pasadena/Woodland Hills, CA
By Jon F in forum Parts For Sale / TradeReplies: 5Last Post: 11-03-2006, 11:06 PM -
By Jon F in forum Western MembersReplies: 1Last Post: 11-03-2006, 10:00 AM -
Rapid Motorsports 402 Cam and Morel Lifters
By Camaro SS in forum Parts For Sale / TradeReplies: 0Last Post: 06-27-2006, 04:10 AM
