Thread: Just swapped 5.3 to 6.0 lq9
01-17-2016, 05:05 PM #1Junior Member
- Jan 2016
- Charlotte nc
Finally got the swap done now I'm searching for a used supercharger. It went way smoother than I thought I wish they all came with the 6.0
01-18-2016, 03:18 PM #2
Welcome to the site!
What vehicle underwent the swap?
01-18-2016, 06:26 PM #3Junior Member
- Jan 2016
- Charlotte nc
I sold my 09 duramax😢 and bought an 04 z71 Suburban, I have to have a 4x4 for work and I drive 50 to 60k a year. Got the burb with 140k 2 years ago. Now it has 260k, the 5.3 started chirping and was positive it was the lifter bearing, (confirmed when removed) I found a LQ9 from a 2003 escalade, salvage yard told me 115k for ($1075) so I drive 3 hours to save a thousand when I got there i asked to see the vehicle it came out of. I noticed the oil change sticker in window that said next change at 151k so the took off $300 basically no Core charge. I don't have time to swap myself so had a small garage door swap for $600😟 ( wish I could have done myself) my Suburban has flex fuel so had to use my injectors (different connection) and I swapped oil sending unit someone else said to. Everything else was plug and play.
01-19-2016, 04:53 AM #4
Did you swap out the PCM as well (or have it tuned) for the 6.0?
01-19-2016, 05:04 AM #5Junior Member
- Jan 2016
- Charlotte nc
That's the interesting part I read on another forum for this same swap the guy did not change it. However I do notice an increase in power but I am going to buy the PCM from the escalade the engine came out of see what kind of difference it is then send one of them off for a tune. Maybe Frost?
01-19-2016, 03:58 PM #6
That's where I would start.
01-20-2016, 12:10 PM #7
Welcome to the site, Josh
Help: Need help with swapped 02 silverado
By Colton in forum General HelpReplies: 3Last Post: 01-06-2016, 05:43 PM -
Just swapped to a 3.73
By 08STiguy in forum DrivetrainReplies: 22Last Post: 03-16-2015, 07:05 PM -
So what all has the LS been swapped into?
By Roothawg in forum Domestics and ForeignsReplies: 18Last Post: 06-13-2011, 02:33 PM -
T/A's with new/swapped engines
By Gohard in forum General HelpReplies: 10Last Post: 05-15-2010, 03:21 PM -
was it swapped?
By LSCyaL8R in forum General HelpReplies: 28Last Post: 08-03-2009, 03:04 PM
