    Mike The Guz's Avatar
    Lawndale, CA
    Artic White
    2002 Camaro SS
    2010 Camaro Paint Correction+Optimum Gloss Coat(New Formula)
    This car belongs to my uncle. He asked me if I could polish it out as he will be giving it to his son as a gift for his 18th birthday on December 23rd. He's a good kid so I went the extra mile and coated the car after correcting it. This was a full interior and exterior job. It only has 18k miles on it and it is a V6. Don't let the SS badge fool you lol. My uncle decided he wanted a clone but the exhaust tone gives it away lol.
    This has to be one of my favorite colors that I have worked on.
    This is how it arrived. With a nice coat of dirt on it.
    The defects underneath the layer of dirt
    I started off using this wash method by Mike Phillips (http://www.autogeekonline.net/forum/...shing-car.html)
    Here is Ironx doing it's thing
    Followed that up with a foam bath using Meguiar's Hyper Wash
    There was no sign of any protection on the paint. The water just stuck to the surface
    Pulled it into the garage. This is what I was working with.
    Defects on the trunk
    On the rear drivers side quarter panel
    Went on to clay the car. This is what I pulled out on a small section of the trunk. It was similar around the entire car. There was also some white overspray on a few areas of the car.
    I knew I was going to have to compound but I started off with a test spot with M205 and a Meguiar's thin yellow foam polishing disc. I did this on the door as I also tried a couple other combinations to see what works best. M205 did a good job but the defects were pretty deep. My camera couldn't pick them up.
    Video of the test spot.
    I ended up moving to Meguiar's D300 on a microfiber cutting disc. This was doing a better job but even that was struggling a bit. I ended up using M100 on a microfiber cutting disc. The paint on this is on the hard side. The good news is that both D300 and M100 finished LSP ready. Here's the drivers side front fender after using the M100/microfiber combo. There were some deep scratches on the fender that would require more work than what is needed.
    Lawndale, CA
    Artic White
    2002 Camaro SS
    After compounding with M100 and the microfiber cutting disc, I moved to M205 on a thin yellow polishing disc, followed by Menzerna SF3800 on a thin black foam finishing disc. M100 on microfiber did dust so I ended up doing a quick rinseless with D114 to remove all the compound dust from the paint and from the crevices it found it's way to (ie door panels, trunk, etc). After that I followed up with a couple wipedowns of Carpro Eraser.
    The coating of choice was Optimum Gloss Coats newest formula. Thanks Vega from Autopia for matching the Autogeek cyber buster deal on gloss coat.
    This is what is included in the package. One thing to note is that I did not use the provided foam applicator. I ended up using a CarPro suede applicator and the CarPro applicator block. It worked flawlessly.
    This is a 10cc syringe.
    This is what I have left after applying 2 coats to the paint.
    Here are the end results on the car
    Trunk looking good.
    Driver side rear quarter panel looking good
    It was a bit overcast when I took these
    Lawndale, CA
    Artic White
    2002 Camaro SS
    The interior was not bad. A quick vacuum cleaned up most of it. Followed up with some Meguiar's Quik Interior Detailer and Natural Shine. The rubber was a bit dry. The dirtiest part was the glass.
    My brother came over and he decided to give Blackfire All In One Tire and Trim Protectant a go in the engine bay. This is all he used.
    Before
    After
    Air intake before
    All dressed
    Final shot of my 4th gen behind this 5th gen
    Products used:
    Paint:
    Wash: Meguiar's Hyper Wash
    Decontamination: Ironx, Clay with Meguiar's M34
    Compound: Meguiar's M100 + Meguiar's 5" microfiber cutting disc
    Polish: Meguiar's M205 + Meguiar's 5" thin yellow polishing disc, Menzerna SF3800 + Meguiar's 5" thin black foam finishing disc
    Coating Prep: CarPro Eraser
    Coating: Optimum gloss Coat (new formula). Applied 2 coats
    Tires:
    Meguiar's D143 Non-Acid Wheel & Tire Cleaner at 2:1
    Pinnacle Black Onyx (2 coats)
    Wheels:
    Meguiar's D143 Non-Acid Wheel & Tire Cleaner at 2:1 with various brushes
    Clayed
    Polished with M205
    Detailer's Pro Coating Prep Polish
    Pinnacle Black Label Paint Coating Version 1 (using the remainder I have on the face of the wheels)
    Wheel Wells:
    Meguiar's Super Degreaer
    Meguiar's Hyper Dressing
    Exhaust Tips:
    Meguiar's Medium Cut metal polish
    Meguiar's Fine Cut metal polish
    Wolfgang Metal Sealant
    Trim:
    Front cowl, window trim, roof trim, shark fin antenna, rear valence were cleaned with Mothers Back to Black Heavy Duty Trim Cleaner, dressed with Wolfgang Exterior Trim Sealant
    Glass:
    Clayed
    Detailer's Pro Krystal Vision Glass Cleaner
    Detailers Pro Glass Restorer Polish + Lake Country Tangerine Polishing pad
    Detailers Pro Coating Prep Polish
    Detailers Pro Glass Coating
    Interior:
    Meguiar's Natural Shine
    303 Fabric Guard (seats & floor mats)
    Engine Bay:
    Adam Lug Nut Brush
    Blackfire All In One Tire & trim Protectant
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Looks good! Nice write up.
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Member RONS98TA's Avatar
    MARYLAND
    BLACK
    1998 PONTIAC TA
    WOW!!!! What a difference. Excellent work man. I guess you can probably kick some a$$ using the "karate kid" technic. "Wax on....wax off" LOL. How many hours did all that take?
    1998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
    Lawndale, CA
    Artic White
    2002 Camaro SS
    Quote Originally Posted by Ed Blown Vert View Post
    Thanks.
    Quote Originally Posted by RONS98TA View Post
    Thanks. I think it was like around 20-30 hours.
    2002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
    Member SuperSSguy's Avatar
    Jul 2012
    NorCal
    Sunset Orange Metallic
    2002 Camaro SS M6
    Looks Great!! Your Cousin must be really happy to have such a nice ride @ 18 What a cool Cousin you are!! Best of Luck to him and Happy Driving !
    LOL @ the SS badge on a V6 car. Nice write up. GM paint is very hard stuff. Nice move tossing the Optimum applicator-it bounces around a lot during application. Now that you tried OPT, check out Gtechniq Crystal Serum, that will make OPT feel like sand paper!
    Custom Car Emblems
    from third_shift|studios
    jaison tortorea
    Lawndale, CA
    Artic White
    2002 Camaro SS
    Thanks. I have GTechniq CSL+Exo lined up for my daily driver.
    I will be comparing this to the Gloss Coat and a couple other coatings I have tried. Hard to beat the ease of use of Gloss Coat.
  1. 2002 Black Corvette Paint Correction + Optimum Gloss Coat
    By The Guz in forum Showcar and Detailing
    Last Post: 10-28-2016, 11:00 PM
  2. paint correction/detail black paint
    By 98maro in forum Showcar and Detailing
    Last Post: 08-24-2013, 03:02 PM
  3. '99 Blk Camaro Z28 Paint correction
    By 01SOMSS! in forum Western Members
    Last Post: 12-14-2010, 11:50 AM
  4. '99 Blk Camaro Z28 Paint correction
    By 01SOMSS! in forum Showcar and Detailing
    Last Post: 12-12-2010, 08:25 AM
  5. Anyone paint the stock grill gloss black?
    By Maro99 in forum Appearance Section
    Last Post: 07-28-2006, 10:04 PM
