Results 1 to 10 of 10
Thread: C5 rear mount turbo question?
12-17-2015, 12:59 AM #1Junior Member
- Jan 2012
- copperas cove,tx.
I have a 1998 C5 corvette with 232/234-112 lsa futral f14 camshaft,low lift..I believe 585 lift on each side.The car is 4l60 with Circle D 3600 stall and 3.90 geared.I recently added a rear mount 76mm turbocharger with intercooler.I am using stock manifolds with vbands welded on and entire turbo build is fabricated.My heads are stock and unmolested.I believe 806 castings but do have the valvetrain upgraded with dual springs,etc.Intake is a stock ls1 and TB is a bbk 85mm with spacer..My question is..Will I be able to achieve over 550 rwhp with this combo and rev it to 6k even with the positive overlap of the camshaft?My car is at the tuners at the moment..The car is dropping off drastically on power @ 5k rpm at only 5lbs of boost.The fueling,afr, and pressures are ideal as my tuner tells me.Any and all info is appreciated.I just want my car to at least rev to 5700 before dropping off.I believe the cam is rated for 6500 rpm.Its being tuned on E85 and has walbro 450lph e85 pump with hotwire and siemens deka 80lb high impedence injectors.Thanks guys
12-17-2015, 08:20 PM #2Junior Member
- Jan 2012
- copperas cove,tx.
Nobody?Really?
12-18-2015, 09:02 AM #3
Honestly, I think 550 to the wheels is a stretch @ 5 psi. Especially if you haven't done anything to the heads. I'm surprised you're only achieving 5 pounds of boost with being intercooled. Something doesn't jive.
I'm also curious why you care about what the engine will rev to. What are you trying to accomplish with the car?Last edited by FasstChevys; 12-18-2015 at 09:04 AM.
12-18-2015, 04:01 PM #4
I'm reading his post as the car only makes 5psi, not that he was expecting to only achieve that. I could be wrong.
12-19-2015, 05:46 AM #5
Sounds to me the car should be able to make 500+ hp with no problem. If you are only seeing 5psi of boost, the you must have a clamp or 2 loose somewhere, causing a boost leak. Recheck all your clamps or you might even want to go as far as doing a boost leak check. Use an air compressor and a gauge and check how much boost the cold air intake tubing can handle. I would guess you should be able to make at least 15lbs of boost with that setup.
1998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
12-19-2015, 07:52 AM #6Spaz is My Mentor
Correct spring for the blow off valve?
12-20-2015, 07:40 AM #7
12-20-2015, 07:44 AM #8
12-20-2015, 12:25 PM #9
That's my guess...a leak somewhere.
12-20-2015, 12:27 PM #10
Unless the car is making more than 5psi, but isn't making the power. Then that's another story. OP doesn't really say what max boost/power was.
Question: C5 rear mount turbo question?
By rthackwray in forum NitrousReplies: 0Last Post: 12-17-2015, 12:52 AM -
Done with the Rear Mount Turbo!
By cailey37 in forum Forced InductionReplies: 23Last Post: 09-07-2011, 10:40 AM -
Wanted: sts rear mount turbo 99 camaro ss
By 99SNAKESKINNER in forum Parts Wanted / TradeReplies: 0Last Post: 11-04-2009, 07:39 AM -
Rear Mount Turbo
By Txyoungguns in forum Forced InductionReplies: 6Last Post: 02-16-2007, 06:13 PM -
Rear Mount Turbo in the 7's
By JD_Z28 in forum Multimedia SectionReplies: 11Last Post: 09-13-2006, 01:19 PM
