Results 1 to 3 of 3
Thread: Dim headlight passenger side
11-22-2015, 02:30 PM #1Junior Member
- Mar 2009
- Orangeburg S.C.
Silver- 00 Z28 B4C
It does not appear to be the same problem everyone else is having atleast ground wise. My problem is all 3 other headlights burn but look like they are correct brightness. The passenger side dim looked like it was burnt out but when I replaced it, it's still not working. I'm guessing this could still be a corroded main harness but could there be any other reoson? Also are they the same part number for both sides of dim or will the bulb work on either side?
2000 B4C Z28. Awaiting mods.
01-01-2016, 03:25 PM #2
The driver side and the passenger side dims are the same part number and bulb. They will work on both sides. You could turn your lights on, open the hood, and squeeze the main harnesses and see if it makes a difference. Mine would be dim, and I would press the large connector together, and they would go back to normal. I temporarily put a tie wrap around the connector holding it together until I hardwired it in. After the hardwire, I never have had this problem again. Hope this helps.
Ported/Polished throttle body, Lingenfelter launch module, SLP line lock, QTP exhaust cutout, LS7 clutch, K&N, Ceramic coated longtubes, no cats, 3" exhaust, Flowmaster "B", Eibach springs, Midwest Chassis 9" rearend w/4.10's
01-02-2016, 10:49 AM #3
Swap the lights from side-to-side and see what happens. Could be corrosion in a harness connector or at the plug connected to the bulb.
WTB: Passenger side headlight cover
By tatertot91 in forum Parts Wanted / TradeReplies: 0Last Post: 08-16-2010, 04:56 PM -
wtb: passenger side headlight assembly 98-02 T/A
By Archaelas in forum Parts Wanted / TradeReplies: 0Last Post: 12-03-2009, 06:48 AM -
Wanted: Firebird Passenger Side Headlight Assembly (98-02)
By Zaccagnini in forum Parts Wanted / TradeReplies: 0Last Post: 10-21-2008, 04:26 PM -
Need ASAP Need passenger side headlight motor
By dan00k in forum Parts Wanted / TradeReplies: 0Last Post: 05-30-2007, 03:25 PM -
Rebuilt Passenger Side Headlight Motor (on ebay) OBO
By Marc1130 in forum Parts For Sale / TradeReplies: 0Last Post: 08-13-2006, 10:31 PM
