Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: Oil leak
    Junior Member Jonarin's Avatar
    Sep 2015
    Buffalo NY
    Oil leak
    Hey guys, I just bought a 01 Trans am ws6. It has 107k on it, hasn't been drivin that much in the last year. Btw, I just bought it yesterday. But anyway, the guy that sold it to me mentioned that it has a small oil leak. So I drove it home, and parked it in the garage, and noticed it was dripping oil quite a bit. It looked like the oil pan was covered, and looked like it was leaking from the rear main... I mean, as I read up on these problems it looks like it is common. How do I actually diagnose it is the rear main seal? Thanks guys.
    Sep 2015
    Buffalo NY
    Oil leaking
    I have an oil leak, that looks like it is coming from the rear main seal. How can I actually tell that it is coming from there?
    Before you tear out your transmission, check this first.
    Reach back on the drivers side of the intake. You should feel something about 3" long sticking up from the back of the motor that has a wire harness connected. It is your OPSU. Feel around here to see if it's leaking oil. Sometimes when they crack they spew oil down the back of the block and it looks like a rear main seal. If it's dry then the only way to confirm it's the rear main is to drop the transmission, remove the flywheel.
    Now if the OPSU is cracked you have 2 options to fixing it. One is (very difficult) try to remove it without removing the intake with a OPSU socket (parts stores sell them for $10). Good Luck very hard to do unless you have small hands and are good at blind work. The other option is take the intake off, takes about 2-3 hrs for beginners and about 45mins -1.5 hr for experience guys to do.
    ^^ This. FWIW, I thought I had a rear main leak on our car and it turned out to be the oil pan gasket.
    Sep 2015
    Buffalo NY
    I head about the opsu. I can't get my hand back there. Maybe I can but a extended mirror or something to see
    I merged the threads.
    Sep 2015
    Buffalo NY
    Thanks bud
    One more indicator that the OPSU is cracked, is your oil pressure fluctuating like bouncing around erratic without giving an revs?
    Sep 2015
    Buffalo NY
    Oil pressure Guage is fine
    Sep 2015
    Buffalo NY
    I confirmed in what the rear main seal.
    Greensboro, NC
    2002 Trans Am WS6 M6
    If it's a manual and the clutch is original you might as well do it while your fixing the seal since you have to drop the trans. Did my rear main and clutch at the same time around 110k.
    Sep 2015
    Buffalo NY
    It's an automatic. And I am probably going to take it to a transmission shop
    Senior Member kingls1's Avatar
    Apr 2011
    Johnstown,PA
    1999 Trans-Am, 2012 Sonic
    Not sure if that year had the new PCV valley plate (LS6) part of my oil leak was from the cracked PCV hose running around back side of the intake. Also my oil pan gasket was contributing factor. When I pulled my trans to replace the clutch rear main was perfect. Changed it anyhow cause I was there.
    99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
    Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
    Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
    Wish list.
    Coil overs, Heads & Cam
    I have a nice detailed thread with pics on how to pull the transmission. Let me know if you want to tackle it and I'll post up a link. Honestly, it is not all that difficult to do.
    Sep 2015
    Buffalo NY
    Put the link on here.
    Sep 2015
    Buffalo NY
    Yeah I think I'll pass on that ugh
    Ok. If you take it to a shop make sure that they have the proper alignment tool to install the rear cover plate (if it does turn out to be the rear main).
    Sep 2015
    Buffalo NY
    Ok. How much do you think it would be if a shop were to do it
    Sep 2015
    Buffalo NY
    [IMG]https://images.tapatalk-cdn.com/15/09/03/2c9c1cb7456aed9d65a145fd96763f1a.jpg[/IMG
    And where the light is, and I supposed to have that little half circle?
  1. Help: OIL Leak!!!
    By joedude02 in forum General Help
    Last Post: 12-05-2010, 07:59 AM
  2. Help: oil leak
    By sutie in forum Internal Engine
    Last Post: 10-25-2009, 04:34 PM
  3. Serious oil leak
    By Eagle in forum Internal Engine
    Last Post: 09-28-2007, 04:54 AM
  4. ttop leak, hatch leak, and window motor problems
    By ATCharming in forum General Help
    Last Post: 07-23-2007, 02:30 AM
  5. how serious is PS leak?
    By 02WS6dream in forum General Help
    Last Post: 10-16-2006, 04:44 AM
