Results 1 to 20 of 22
08-20-2015, 02:42 AM #1Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
Fuel presure dropping after shut down.
I know this is a LS1 sight but like other guys I have more than one ride to keep up.My wife have a 2003 ford sport trac with the 4.0 engine that is giving me problems, I hope some of you can help me get it fixed, I can smell gas coming from the truck I have checked for fuel leaks top and under truck nothing,I ran a fuel pressure test and it showed 64 which I was told was good but the minute you shut off the truck the pressure drops fast to 0, could it be injectors leaking , and if so would I smell gas like I do if they were doing so at the tip and not outside where I could see it.need help this is my wife's work truck and she
is in it 5hrs a day need to solve this as soon as I can.the truck have 161,000 miles on it.
08-20-2015, 05:05 AM #2Junior Member
- Sep 2013
- pa
black- 2004 gto
if the truck a fuel pressure regulator on the return line at fuel rails pull the vacuum line and see if gas runs out . the diaphragm goes bad and leaks through the vac port . that is if it has that style of injection with a return. to tank .
08-20-2015, 08:16 AM #3
is the truck running ok? Have you tried turning the key on/engine off and checking pressure that way? Is smelling gas the only symptoms you have I guess is my main question or is the truck running badly? Any codes? If it's just fuel odor I would check evap lines/canister too and make sure none are leaking although you technically should have a code if those are leaking. How strong of an odor are we talking?
08-20-2015, 11:32 AM #4Junior Member
- Apr 2006
- Michigan
Black- 2002 ws6
I'm on here looking up the same issue on my 2002 ws6. The fuel pump has a check valve built in, if that fails, you'll lose pressure as soon as you shut down, and have harder start as it needs to prime the lines every start.
I'm looking for info on adding a secondary, in-line check valve to help out rather than pulling the fuel pump itself...
--alex
08-20-2015, 05:15 PM #5
you're thinking the fuel pressure regulator I think.....it's part of the module. Someone on here did have a part number for it at one time but I forget who it was....I think it was pajeff.
08-21-2015, 04:54 PM #6
The regulators for the LS1's were tough to come by, but I did track them down. I will check to see if I can find the thread.
08-21-2015, 04:59 PM #7
Well... nuts. Here is the thread: http://www.ls1.com/forums/f6/still-b...essure-180422/ But no part number.
Searching on line, I found this (it is a Delphi unit): 1998-2001 Pontiac Firebird Fuel Pressure Regulator - Fuel Injection - Delphi 98-01 Firebird Fuel Pressure Regulator - 4675-05168725 - PartsGeek
08-22-2015, 01:04 AM #8Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
The smell is pretty strong I have checked for leaks I have no codes and the truck seems to run ok but I feel it has run better, the smell seems to be strongest when the weather is hot. The smell seems to be coming from under the truck close to the gas tank but I can't find any leaks, I will be getting back under it and check all the hoses on the tank.I have put new plugs and wires on it but I my need to go on and put on a new coil.I will report back and let you guys know what I find Thanks.
08-24-2015, 07:57 PM #9Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
I have found the source of my problem, I have a line on top of the tank that is spraying gas from the connection to the fuel pump,there is two lines on top of the pump I hope one of them
is
a return line , I hope to lower the tank and try to fix the leaking line, I have never removed the fuel lines on a ford so I hope someone on here can give some pointers.I have watched it done on line but there is nothing like doing it your self.My wife have one day off work so the pressure is on me to get it done tomorrow,wish me luck.remember it's a 2003 ford sport trac not my 99 TA.Last edited by Street Fighter; 08-24-2015 at 08:10 PM.
08-24-2015, 08:09 PM #10Spaz is My Mentor
There are plastic clips that hold the lines to the pump assembly. its possible one is cracked or broken.
Did you do the trap door? You should be able to disconnect without dropping the tank.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
6.0L Block - Forged 403ci
, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
08-24-2015, 08:18 PM #11Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
08-24-2015, 09:01 PM #12Junior Member
- Aug 2015
- Zachary la
just put a new fuel pump in it and be done.
08-24-2015, 09:07 PM #13Junior Member
- Aug 2015
- Zachary la
ws6- I have a 4th gen trans am and the trap door location is obvious once you've located the mark. pull up the carpet and there will be lines that like an factory crease. look for the half line and its right above it cut about like a 12" by 10" square with a rotary tool after you get under your car and loosen the strap bolts that holds your tank. do not have to drop the tank, just need enough space for the cutting wheel so you dont cut into your tank.
08-25-2015, 01:32 AM #14
08-25-2015, 02:13 AM #15Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
I second that ,why would I buy a new fuel pump and still have the same problem which is a leak at the conection on the line.
08-25-2015, 02:43 AM #16
another piece of the post that was missed.......
I've never done fuel lines on one of those but how hard can it be right? Getting to it will be the biggest bitch. Wonder if it's like any other pick up truck and easier to just pull the bed off than to drop the tank. I've had the bed off of a ford ranger and it's literally 6 bolts and a couple electrical connections to the tail lights ( 2 of the bolts were a different length so pay attention to the bolts). Easier with 2 people but me and a buddy had his bed off to replace a broken leaf spring in about 15 minutes. The sport track has a plastic kick panel that runs the bottom of the the bed rails but if you can get to everything you may be better off just pulling the bed off.
08-25-2015, 03:51 AM #17Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
08-25-2015, 06:02 AM #18
I Am not sure about the 2003 ford sport trac, but my 2001 Chevy Silverado 1500 fuel tank was pretty easy to drop. Just 2 bolts hold the tank to the frame, and the few bolts holding the fuel filler neck to the truck also. I used a few 2x4's and a hydraulic jack to lower it down just enough to get to the top of the tank. Obviously the less fuel in the tank, the better off you are, but I don't think it will be to bad to do. Good luck.
1998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
08-25-2015, 06:33 AM #19Spaz is My Mentor
Sorry OP, I was thinking this was a F-body when referring to the trap door. I had posted my msg from my phone and didn't see it wasn't.
But the plastic clips I was referring to is still valid. Here is what I was referring too.
08-26-2015, 03:12 AM #20Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
Thanks to all that gave me advice on this issue, I got her done.I ended up replacing the pump, one of the nipples on the pump was cracked and was spraying the fuel under the cab, I feel a lot better knowing my wife is safe driving the truck .once again thanks.
Help: fuel pressure dropping
By joedude02 in forum General HelpReplies: 15Last Post: 10-24-2020, 03:27 AM -
injector presure leaks down
By TryMe in forum General HelpReplies: 4Last Post: 07-14-2009, 04:45 AM -
will faulty oil sending unit cause fuel pump to shut off
By 98z28duval in forum General HelpReplies: 8Last Post: 09-15-2007, 09:33 AM -
Oil presure
By jay98ta in forum Internal EngineReplies: 3Last Post: 10-07-2005, 06:27 AM -
Oil presure
By jay98ta in forum Internal EngineReplies: 0Last Post: 09-29-2005, 05:11 PM
