Results 1 to 20 of 22
    Senior Member clg82's Avatar
    Feb 2007
    California
    2000 Trans Am
    Help upgrading stock suspension....
    Hey everyone, the only thing suspension wise I have done to my TA is remove the rubber spacers at the top of the rear springs....to give it a lower stance in the rear.....if I wanted to replace the stock shocks with something nicer what would you suggest? My TA spends most of it's life in it's own storage unit and only gets out and about on the weekend so it's not a track car....thanks for any help!
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    It would greatly depend on your budget, but the best performing shocks on the market are Koni's. Second to that, which is still a very nice shock, is Bilstein. It sounds like perhaps Bilstein would suit your needs best based on the amount of and style of driving you do.
    I agree - Bilsteins are the way to go.
    Feb 2007
    California
    2000 Trans Am
    any particular part number for the bilsteins that you suggest?
    I don't recall how many different iterations they have for f-bodys, but I believe the HD's are the ones you want. You can buy them as a pair for the fronts only, rears only, or as a kit for front and back.
    Feb 2007
    California
    2000 Trans Am
    Thanks 35th I appreciate the help. Since it has the stock springs on it. Aside from the lowered rears from removing the rubber bushings up top. Should I just get the HD shocks for a stock suspension?
    OP, you're going to want to put that dampner(the rubber piece at the top of the spring) back in. Over time it's going to wear through the metal and then you're looking at serious repair. If you don't at least use some hose and feed it on tho the top of the spring to give it some cushion.
    Hotchkis has a 1" drop spring set that does really well and isn't a big chunk of change. Pair with the shocks and you're good.
    Feb 2007
    California
    2000 Trans Am
    Feb 2007
    California
    2000 Trans Am
    I forgot to mention I did add some rubber hose up top to alleviate the damage it could of done. So what biksteins are we recommending for the slight drop in the rear?
    Member 99'CajunFirehawk157's Avatar
    39466 USA
    Bright Red
    99 Firehawk #157 Roadster
    Thumbs up
    AFAIK other than SLP Bilsteins, they only make one for our cars (example 93-02 Bilstein HD Shock Package (Set of 4 | WS6store.com) and I am about to take mine out, I have a koni setup going in with my bmr 1.25" drop springs I have in now.
    Regards,
    Todd
    #cajunhotrodder on instagram
    Senior Member Naaman's Avatar
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Koni has a sale going on till the end of the month, in case that matters. Might off set the price difference with the Bilstiens.
    Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
    39466 USA
    Bright Red
    Thumbs up
    Quote Originally Posted by Naaman View Post
    That is exactly how/why I bought mine, save about a $1oo off retail afaik! YMMV
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    Quote Originally Posted by 99'CajunFirehawk157 View Post
    Was there something wrong with the Bilsteins? I've had them on my car and I have been pretty happy with them.
    Feb 2007
    California
    2000 Trans Am
    Ok fellas give me some insight on what everyone thinks about a good koni/strano combination.....and what "packaged deal" from strano everyone suggests.
    Member DarrenWS6's Avatar
    May 2015
    Blossburg, PA
    Silver Metallic
    2000 Trans Am WS6
    Can't add input but I can say I will be saving up for that exact setup for next year. No body dislikes that combo!
    2000 Trans Am WS.6 M6
    SLP lid & bellow w/ K&N, GMMG catback w/ Corsa Clones, UMI SFC, UMI Adj. Panhard, UMI Adj. TQ arm w/ relocation kit, QTP Longtube headers ORY, LS6 intake, EGR/A.I.R delete.
    Eibach prokit, Bilstein HDs, Nitto NT555s, skip shift elim, whiteface overlays, 20% tint, matte black decal/overlays
    YouTube.com/DarrenWS6
    I have the Koni 4/4 shocks and Strano lowering springs on all 4 corners on my car. Love the stance and how it handles. It's arguably the best combination you can get.
    Feb 2007
    California
    2000 Trans Am
    35th i swear you are the only person that is on these forums these days anymore lol.....what do you mean by koni 4/4 shocks? i am trying to find on the strano website those shocks but am unable to find 4/4 anywhere on there.
    He calls them Koni Sport Set or Koni Yellows. They are the on-car adjustable ones; yellow/black.
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    I have the same set up. It's great, with one caveat.
    I bought the car with stock springs, and Koni shocks (front) and Bilsteins (rear). The first "suspension" upgrade I did was the sub-frame connectors. Made a world of difference to the car's "integrity" in handling response. Much more direct feeling and taut. Then, I upgraded to Strano's hollow sway bars (the original, non adjustable set). This made the car perfect in regards to ride quality and handling for my purposes. Then I upgraded to Strano Springs. The immediate impression was that the ride was harsher than I wanted, but also much tighter with less (almost no) body roll. After putting a couple thousand miles on the springs, either they have "softened up" after a break in period (not even sure if that happens) or I have acclimated to it. I really like the ride now.
    If I had it to do over again, I would be just as happy on stock springs with sway bars and Konis. But I do like the Stranos for the performance benefit. It feels like an equal trade-off to me (but the car looks better on the Stranos).
    You've probably gotten used to it. Steel springs can go quite a few cycles (hundreds of thousands) before their load rate changes, especially if they're not going solid, which springs in a car won't ever do.
  1. For Sale: Stock suspension $25+
    By 98TransAmWs-6 in forum Parts For Sale / Trade
    Last Post: 03-26-2014, 01:55 PM
  2. Replies: 6
    Last Post: 12-30-2011, 11:40 AM
  3. Upgrading Suspension/Lowering
    By TheShadow in forum Suspension and Handling
    Last Post: 03-01-2011, 10:59 AM
  4. Upgrading shocks with a stock suspension
    By Zapper2003 in forum Suspension and Handling
    Last Post: 02-26-2007, 02:16 PM
  5. Stock suspension
    By melwoods in forum Suspension and Handling
    Last Post: 08-21-2005, 10:21 PM
