08-05-2015, 06:06 AM #1Junior Member
- Jul 2015
- camp hill pa.
black- 99 trans am
Shock suggestion for 99' trans am (non ws-6)
Need to upgrade stock parts and need a decent suggestion.
Added c-5 vette rims
tire sizes are 275/40ZR18 and 245/45ZR17
-Not a z-06 that the wheels came off
And in addition to shocks all around maybe add bumper stops on the rear.
Any suggestions would help. Price hard to say but if you have a similar car/tire setup and like it I would more easily commit.
Thanks in advance!
08-05-2015, 07:21 AM #2Spaz is My Mentor
If the car is to be used for everything else but heavy track or autox use then SLP Bilstein shock set of 4 (Strano Performance $385) will cover you.
If you're into heavy track, autox or street "activities" then Viking or Koni shocks.
For "bump stops" Strano sells a set of 2 for $28 but they do require some trimming of the location tab on the frame. It's not hard to remove and doesn't hurt the frame as long as you shoot it with some rust preventive and paint. I've had mine on for over 5 yrs now.
If you're looking at upgrading the shocks for handling you'll also need to look at springs. Everyone will have their favorites and some springs are for specific types of driving. Drag pack shocks are for the track. I am using Hotchkis 1" drop springs. For me they have performed very well on the street and hwy. Car drives like it's on rails going into turns, but then again I have quite a bit of suspension upgrades too.
08-05-2015, 07:53 AM #3
08-05-2015, 08:27 AM #4Junior Member
- Jul 2015
- camp hill pa.
black- 99 trans am
Really just street use. Just want to replace existing and at the same time put on what others may have found to work well.
I would consider shocks and springs and do any suppliers offer a full "kit" you might suggest?
08-05-2015, 09:05 AM #5Junior Member
- Jul 2015
- camp hill pa.
black- 99 trans am
Link to what your suggesting below? I also have a call into Strano to order the other parts.
I also suggest replacing the panhard rod (to a minimum of a UMI panhard, if not a watts link), control arms and spring isolators while you are at it. The bushings are probably toast by now.
08-05-2015, 10:39 AM #6Spaz is My Mentor
Panhard Bars : UMI Performance, Inc.
The shocks and springs I was mentioning you'll have to go to their site. He's not a sponsor so we can't post direct links.
- - - Updated - - -
Here is UMI's site. They can take care of most of your suspension needs.
http://umiperformance.com/catalog/in...=index&cPath=7http://www.ls1.com/forums/f7/my-6-liter-build-174257/
6.0L Block - Forged 403ci
, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
08-27-2015, 07:00 PM #7
front shock lower springs, shock mount mod?
By JayTA98 in forum Suspension and HandlingReplies: 0Last Post: 12-24-2011, 03:48 AM -
shock 'n' stal! [kinda like shock n awe?]
By third_shift|studios in forum Suspension and HandlingReplies: 4Last Post: 04-24-2008, 08:31 PM -
Have a suggestion.......
By clg82 in forum Request and FeedbackReplies: 4Last Post: 02-26-2008, 09:22 PM -
just a suggestion...
By NE98LS1 in forum Request and FeedbackReplies: 0Last Post: 01-09-2006, 08:43 AM
