07-31-2015, 09:23 PM #1
FX Stage 2 Clutch + Lightweight Flywheel 5.7 LT1 $299.99+
I have a Clutch Kit Stage 2 with a Lightweight Flywheel. I have the copy and paste the actual item specifics here. I paid 435.00 For it. This is Brand New, never installed. You can check out my feedback rating and wish it to be recorded transaction i left the link below.
$299.99 is the starting bid you can win it for that amount. Thats cheap, just a flywheel alone is that much brand new.
FX Stage 2 Clutch Chromoly Flywheel 1993 97 Camaro Z28 SS Firebird 5 7 LT1 | eBay
FX Racing Stage 2 clutch kit is a step up from our Stage 1 clutch kit. This is a versatile set up for the street and on the track. It provides a smooth engagement yet it can holds 50%+ more power over stock clutches. This is a direct factory replacement clutch kit thus no modifications are needed and the clutch kit includes only the highest grade components from world's leading high performance clutch manufacturer. The Carbonized kevlar friction material is used on all Stage 2 clutch kit to have higher burst strength and heat tolerance. The heavy-duty sprung center with heat treated springs and retainer rivets to increase strength and reliability. The FX Racing pressure plate features special single diaphragm design to increase clamp load. It features induction hardened diaphragm, CNC machined castings, stronger drive straps and rivets. FX Racing pressure plate provides smooth and precise feel with easy modulation. All FX Racing pressure plate is load tested on a special testing tool for quality assurance.
This complete clutch kit includes:FX Racing Heavy-Duty Pull-Type Pressure PlateFX Racing Stage 2 Steel Back Carbon Kevlar Disc (11" , 26 spline)Release BearingPilot BushingAlignment ToolInstallation Guide
Horsepower Rating: 490 HP / Torque Capacity: 450 ft/lbs
FX Racing Lightweight Chromoly Flywheels are made from 4140 one-piece forged chromoly steel. They are specifically designed to reduce weight and inertia for better engine response. Most incorporate special design features to enhance the air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel which has the possibility of separating from the flywheel. All FX Racing Chromoly flywheels have passed engineering tests to 12,000 rpm.Ultra heavy-duty and weighs only 22.3 lbs
External balance weights are included in the hardware kit supplied with the flywheelMeets or exceeds SFI 1.1 certificationMade from 4140 forged chromoly steel (2X stronger than billet steel)FX Racing Lightweight Chromoly flywheels incorporate special design features to enhance the airflow for improved clutch coolingFX Racing Lightweight Chromoly flywheels work with every clutch including Exedy, ACT, Fidanza, Clutchmasters, and other OEM clutch kitsCAD designed, CNC machined and computer balancedIncludes a set of 6 ea. brand new flywheel mounting bolts and an external balance weight
Retail Price: $ 1229
FX-82040R1-SS; 82040FX-HT #44Last edited by karpetcm; 08-14-2015 at 12:02 PM.
08-01-2015, 07:24 AM #2
bump...
1993 Z28 M6: K&N Intake, 52mm TB, TB Bypass, No Cats, Exhaust Cutout, Flowmaster Muffler, 3.90 Gears, 160 Thermo, Tune, BMR Springs, Bilstein Shocks, 3 Point SFC,s & MGW Shifter.
08-02-2015, 06:17 AM #3
bump.
08-11-2015, 09:28 AM #4
bump. Price is in the link.
08-14-2015, 12:02 PM #5
bump.
For Sale: FX 4140 Lightweight Chromoly Flywheel 93-97 V8
By karpetcm in forum Parts For Sale / TradeReplies: 0Last Post: 12-05-2015, 05:33 AM -
Monster Stage 4 Clutch and Lightweight Flywheel
By ls1camino in forum Parts For Sale / TradeReplies: 0Last Post: 03-28-2013, 04:28 AM -
Monster Stage 4 Clutch and Flywheel
By ls1camino in forum Parts For Sale / TradeReplies: 0Last Post: 08-10-2012, 04:41 AM -
Spec Stage 3 clutch, aluminum flywheel, underdrive pulley
By KapsZ28 in forum Parts For Sale / TradeReplies: 8Last Post: 08-21-2007, 08:02 PM -
NIB Spec Stage 3 Clutch/PP and Billet Steel Flywheel
By greatwhitess in forum Parts For Sale / TradeReplies: 1Last Post: 10-25-2006, 05:04 AM
