Results 1 to 2 of 2
07-27-2015, 05:37 PM #1Junior Member
- Sep 2012
- davenport iowa
Just installed rack and pinion got a probelm
*Just installed rack and pinion got a probelm
I just installed a new rack opinion and used the seat belt through the steering wheel but after i'm done tires are not strait the steering is was off the steering where spins around. Do i not have that shaft hooked up right and should take of the tie rod bolts straighten the wheels by hand then take that shaft back out try to fit it how it goes or something??? Thank you
07-28-2015, 04:23 AM #2
Hard to tell what is going on here... are you saying the steering shaft may not be properly connected to the rack? Any time you replace steering components, such as the rack, tie rod ends and such, an alignment is recommended. I always carefully measure the old stuff and set the new parts as close as I can to make the car driveable.
New Rack/Pinion installed - now steering wheel is off center
By Neil in forum Suspension and HandlingReplies: 5Last Post: 03-12-2016, 10:41 PM -
Which rack and pinion?
By huitt06 in forum Firebird / WS6Replies: 4Last Post: 10-29-2014, 04:25 AM -
rack & pinion
By RLamas in forum Firebird / WS6Replies: 10Last Post: 05-17-2008, 07:37 PM -
Rack and pinion?
By SPDemon81 in forum External EngineReplies: 2Last Post: 05-31-2007, 06:01 PM -
Rack and Pinion WTF???
By lvbroham1 in forum General HelpReplies: 6Last Post: 07-07-2006, 07:11 PM
