    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    Rear Chassis/suspension "popping" noise
    Hi all,
    Anyone ever hear a "popping" noise from the cars rear chassis/suspension when their cars weight shifts?
    I notice it the most when I am parked "nose-in" and I pull out of the spot in reverse, turning left. When the car pretty much comes to a stop, after the 90' turn, I hear "popping" sound as if the suspension all of a sudden has lost tension between two components.
    This sound has been there before and after relacement of the panhard rod, LCA's and winter and summer tires.
    You check the rubber dampener for the rear springs? If they deteriorate that can make noise.
    I would make sure all suspension bolts/nuts are tighten.
    Sep 2010
    Bel Air, Maryland
    I can't remember, off-hand, does the suspension have an upper and lower spring dampener, and are they visible with out putting the car on a lift?
    It's at the top of the spring that is between the spring and the body.
    You'll at the least need to lift it on stands. Let the rear hang, remove the bottom shock nut and pull the spring to get to it.
    Sep 2010
    Bel Air, Maryland
    Thanks for the info on that. If it is the dampers, I can't believe that the shop that replaced my shocks didnt check them (especially after I specifically asked them to check all of the rubber when they did the work).
    I don't think I want to have the shock disconnected from the suspension in my angled driveway. I might have to try this other shock. Are there any good brands (that dont cost an arm and a leg) for these? I think I will have a shop replace the upper and lower dampers. I figured it was the sway bar bushings or isolstors/dampers. Wasnt too much else left
    Still could be. I just know it's sometimes overlooked.
    Sep 2010
    Bel Air, Maryland
    Im going to try to replace the bump stops this weekend, if I can get to do the bump stops, I'll knock out the sway bar end links too. Still have a full set of those in my inventory
  1. Popping noise coming from suspension
    By iceman504 in forum Suspension and Handling
    Last Post: 11-05-2010, 08:26 AM
  2. front suspension popping noise
    By godless-phoenix in forum Suspension and Handling
    Last Post: 03-30-2010, 11:20 PM
  3. FS: Red 94 Z28 CLEAN "Rolling Chassis" - Californi
    By tireburnin in forum Vehicles For Sale / Trade
    Last Post: 06-04-2009, 05:41 AM
  4. 1969 Firebird "Little Big Chief" Chassis Dyno Test
    Last Post: 07-21-2008, 07:00 AM
  5. Accelerating problem and "popping noise"
    By 94camm in forum General Help
    Last Post: 10-05-2005, 08:38 AM
