Results 1 to 16 of 16
Thread: 4th Gen F lugnut cover/caps
06-15-2015, 10:53 AM #1Senior Member
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
Is there any good source to get lug nut covers/caps for our cars? $4.00 each is taking its toll on my wallet, and I usually leave shops missing a wheels worth each time.
06-15-2015, 12:11 PM #2
That sucks. I'd recommend removing them before taking your car in if that's the case. SLP is the only one I know of who sold OEM lug nut covers off-hand.
06-15-2015, 05:57 PM #3Senior Member
- Sep 2010
- Bel Air, Maryland
It certainly does. People say I am particular with my car, but I think I have simple desires. Stuff should work on the car the way its supposed to, the car shouldnt make odd noises, and I should able to pick my car up with the same amount of things on it that I dropped it off with.
06-16-2015, 02:56 AM #4
Autozone. Running these on all four corners and they are a perfect match. There are both short and tall caps, so make sure you get the correct part number.
Link: Dorman/Wheel Nut Covers 611-605.1 at AutoZone.com
06-16-2015, 12:01 PM #5
06-16-2015, 04:57 PM #6
SLP still carries an entire set of lug nuts and caps for $25.95. Whenever I remove and replace the plastic caps I always put a small dab of black RTV on the inside of the threads to keep it securely stuck on the lug nut.
06-16-2015, 05:53 PM #7Senior Member
- Sep 2010
- Bel Air, Maryland
I was thinking of buying two sets of those.
I was also thinking about some RTV, I am glad to hear that it works.
My biggest problem is the shops been taking them of and either not putting a bunch of them back on, or putting them back on with the impact wrench and cracking them off. I will have a conversation with them the next time they work with the wheels though. Sometimes, it is really hard to keep nice things nice, even when you pay someone else to do it.
I miss not having access to a repair stall/ lift, but the rest of my life has gotten so much better when I left the car biz
06-17-2015, 02:55 AM #8
It would take all of 1 minute to run around the car with a 3/4" socket and check the caps after your car is serviced. A bit of time is always cheap insurance. I have never used RTV on our caps (even though that is a good idea) and during 8 years of ownership only one cap has come off and been lost.
06-17-2015, 10:44 AM #9
In the same boat as Jeff. Lost 1 in owning the car since it was new in 2002. I check them relatively regularly. Now if a shop is losing them, that's another problem all-together. I would be having that shop buy me new lug nut covers, removing them before taking it in, or finding a more competent shop.
06-17-2015, 12:38 PM #10
I'll bet the bank that the shop is using the impact to put them on. I used to work at several dealerships in my younger years and watched the tech's do it all the time. No matter how gentle they try to be they always zap a few on and split them. They just throw them in the trash and move on. They simply don't want to take the time to spin them on by hand.
I always put mine on by hand, never use silicone, and knock on wood, since the mid 90's owning these things I've never lost a single lug cap. However I'm only going 6,000 miles and rotating the tires, so every 6,000 they come off and get a re-torque
06-17-2015, 03:24 PM #11Senior Member
- Sep 2010
- Bel Air, Maryland
I am right there with you guys. I do think its because they use an impact. I used to not have a problem with the shop, but over the last year or so, its gotten worse.
When it was small things, it didnt bug me, but now its getting pretty irritating, especially since alot of the inventory of parts that I bought at employee pricing before I went back to college is pretty dried up. There are a lot of good shops around me, should I not be able to work an accord out with this one.
06-17-2015, 04:11 PM #12
Unfortunately that is a lot of places. Main reason why I don't let many shops touch my vehicles. I had a problem with my Cavalier, 2003 5spd, it was whining/vibrating when turning either direction full lock. Had it in the dealer a couple times, first time they told me I had 1 bad wheel bearing. I replaced both myself, it still did it, went back and they said it was the power steering assembly. So I bought an assembly and had other suspension plans so I held off. One day tinkering I decided to check the fluid reservoir. I open it and it was empty. I top it off, the issue goes away and comes back in a week. Top it off one more, its 100% gone, even today right now it has not lost fluid at all. The cause of this was when I bought the car, the little crap dealer I bought it from had to replace the slave cyl because 5th day I had the car the clutch pedal failed. Turns out when they fixed it for free under the 30 day deal, they dropped the subframe, did not align it, did not top fluids off where they interrupted, and 4 months later I had to replace brand new front tires. Overall, I got screwed over big time by mechanics on the clock.
I try and do everything I possibly can on my own now, and I have learned a lot more 'before you buy this car, check' things.
People these days.
06-17-2015, 05:21 PM #13
06-18-2015, 01:02 PM #14
06-18-2015, 02:24 PM #15
It was probably Orion's cousin.
06-18-2015, 03:31 PM #16
that's how I replaced all the center caps on my 75 cutlass at one time.......then someone would steal a couple.....then I would steal a couple. I think there were caps made for 50% of the cutlass' on the road and then everyone just kept stealing them from one another.
Lugnut Covers
By JOHNNY59 in forum Parts Wanted / TradeReplies: 1Last Post: 08-03-2009, 12:07 PM -
F/S: Chrome Lugnut Covers - Caps
By BandDirector in forum Parts For Sale / TradeReplies: 6Last Post: 04-16-2009, 12:53 PM -
I lost my lugnut key... help !!!
By BLAUPLOW in forum Wheels and TiresReplies: 10Last Post: 02-16-2009, 03:31 AM -
Which lugnut for stock rims?
By TheKitchenSink in forum Wheels and TiresReplies: 1Last Post: 01-28-2009, 05:05 AM -
Lost my locking lugnut key
By JonB in forum Wheels and TiresReplies: 5Last Post: 05-31-2008, 09:52 AM
