Thread: valve cover
    Feb 2008
    jupiter fl.
    2000 trans am
    valve cover
    does anyone has a passage side valve cover off a ls1 engine ,what I need is a picture of the under side so I can see the locking tab that holds the factory fill tube on the cover so I can possibly bend it out of the way to remove the tube whi tout taking the cover off. thanks
    I only took pics of the top of the covers when I polished them a few years back.
    Just for fun, I Googled "ls1 oil fill tube" and came up with a couple of good pics under "Images".
    Feb 2008
    jupiter fl.
    2000 trans am
    thankyou pajeff that's just what I needed to see
    I was afraid to break it and just worked around mine. Even though you really can't see them, a polished stock cover looks pretty good.
    How'd you do it?
    Hand sanded the rougher areas with 400 wet, ran a soft Dryloc over the entire thing with my angle die grinder, and then polished them with a buffing wheel in my straight die grinder. Did not take long at all.
  1. coil cover idea... sbc valve cover
    By BLK2KSS in forum Appearance Section
    Last Post: 11-14-2012, 07:19 AM
  2. Question: Valve Cover 97/98 Z28
    By Paulie in forum General Help
    Last Post: 10-25-2010, 10:03 AM
  3. Help: valve cover too low
    By timowen1 in forum General Help
    Last Post: 10-15-2010, 08:54 AM
  4. Valve cover gaskets, Valve Springs, Timing Gasket
    By Dewman in forum Parts For Sale / Trade
    Last Post: 01-22-2010, 08:14 PM
  5. Valve Cover Breather/ PCV Valve
    By lonewolf37 in forum General Help
    Last Post: 10-26-2007, 02:24 AM
