Thread: Unable to remove PS pulley
06-02-2015, 07:35 PM #1Junior Member
- Apr 2015
- chicago
white- 2001 pont trans am
So I went to Autozone and rented the kit. I followed the instructions from the link below but the pulley will not come off. Did I get the wrong kit am I doing it wrong?
06-03-2015, 09:26 PM #2Junior Member
- Apr 2015
- chicago
(UPDATE) So once I figured out how to use the tools the pulley came right off. Replacing the pump was easy as was removing the lines. I've added a cooler to it and replaced the lines. The only concern I have are the pressure lines where they attached to the bottom. I tighten them as much as I could but they didn't seem to go all the way in. I notice the metal lines that come out of the connectors can be moved side to side. Is this normal? Or should they not be able to move? If not then what am I doing wrong?
06-04-2015, 03:02 AM #3
Which line are you referring to? Can you post a pic?
06-04-2015, 06:57 AM #4Junior Member
- Apr 2015
- chicago
Attachment 26263
i was able to tighten the sending hose so it doesn't move. The return line unfortunately I damaged when I attempted to tighten it
06-04-2015, 08:01 AM #5
Ok - you were referring to the fittings in the rack.
06-04-2015, 08:41 AM #6Junior Member
- Apr 2015
- chicago
06-04-2015, 05:03 PM #7
You can get hoses custom made at lots of garages and truck places. Our local NAPA will make them.
06-05-2015, 06:12 AM #8Spaz is My Mentor
TurnOne has an awesome pulley wheel that you no longer need to remove it to access the bolts. Happiest purchase I've ever made.
Unable to view threads in Mostly anything goes forum...
By firemandan1700 in forum Request and FeedbackReplies: 8Last Post: 05-19-2012, 08:59 AM -
unable to look at for sale section ?
By Dus10o in forum Request and FeedbackReplies: 1Last Post: 11-22-2009, 01:36 AM -
Unable to edit FS thread
By nhra-trans-am in forum Request and FeedbackReplies: 2Last Post: 12-18-2008, 01:03 PM -
Help: Unable to Open Internet Exporer....Please Help!
By SAGGIN in forum Computers / GamingReplies: 20Last Post: 08-14-2008, 03:02 AM -
Unable to Read posts
By CrimsonNJ in forum Request and FeedbackReplies: 1Last Post: 03-06-2006, 01:51 PM
