Results 1 to 3 of 3
    Jan 2012
    Sweden
    Trans am 99
    Noise from the brake fluid reservoir
    I noticed when I lift the hood after I stopped the car that there was a fizzing sound from the brake fluid reservoir and that it was wet on the outside. The fluid didn't look dark or anything but could it be time to change it anyway. It was some years ago I did it, but I haven't driven it to much so it would be because of time in that case, or could it be something else?
    That's odd. Is the lid fully seated and the gasket in place?
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    I feel you have a vacuum leak somewhere near the master cylinder. The MC is void of any consistent air pressure that would cause the "Fizzing" sound you are talking about. You probably had some fluid drip on a vacuum line with a slight leak. Clean up the area with break clean, be careful, and then use a spray bottle with soapy water to find the leak. If that does not do the trick then break out the smoke. Good luck.
  1. Wanted: Brake fluid reservoir
    By 88IROCVert in forum Parts Wanted / Trade
    Last Post: 07-05-2009, 03:23 PM
  2. Help: How to Bleed the Brake Fluid
    By chaosinfinite in forum General Help
    Last Post: 11-13-2008, 11:48 AM
  3. Brake fluid
    By jroc in forum General Help
    Last Post: 08-11-2008, 11:57 AM
  4. DOT 3 / Dot 4 brake fluid question?
    By davered00ss in forum Suspension and Handling
    Last Post: 08-19-2007, 03:01 PM
  5. Brake Fluid Everywhere!
    By Neil in forum General Help
    Last Post: 09-26-2006, 04:52 PM
