Results 1 to 3 of 3
05-25-2015, 10:26 AM #1Junior Member
- May 2015
- Wisconsin
white- 2003 Silverado 2500
99 silverado 2500 6.0 engine into 2003 silverado 2500
Hello Everyone,
Newbie here. This is my 1st post. I came cuz you guys (and gals) are the experts right? I have a 1999 silverado 2500 with the 6.0 motor and push button 4wd. I picked up a 2003 silverado without motor tranny and transfer case. The issue I have is the 2003 has the floor shift. Do I need to get a different transfer case? Will this engine/tranny swap work? I thought about taking the whole dash out of the 99 and putting it in the 2003 just to have everything match up but looks like a major job. Any thoughts or suggestions would be great. Thanks!
05-25-2015, 02:44 PM #2
Get the different transfer case or you'll have to wire up the 2003 for the push button T-case. I'm sure you can buy new (or find used) the factory buttons for the push button case. Then it just has to be wired, and there's a chance it already has the wiring there (doubtful, but possible). I'm not sure if you'll need a BCM for that push button T case.
this post is meant as a joke and in no way should it be interpreted as a serious or meaningful reply. The author of this post cannot be held liable for any damages, both emotional and physical, that may be incurred from the reading of this post. By acknowledging this disclaimer you hereby release the author from any and all liability
05-25-2015, 03:58 PM #3Junior Member
- May 2015
- Wisconsin
Ok. that is kinda the route I was thinking. The manual case seems like the way to go. The guy had a 6.0 in this truck already, so with any luck, the rest should bolt up. Thanks!
WTT or sell, 2003 Dodge Ram 2500
By sskid in forum Vehicles For Sale / TradeReplies: 33Last Post: 06-10-2008, 10:10 AM -
Silverado 2500
By Bouvers in forum Almost Anything GoesReplies: 4Last Post: 01-04-2008, 10:07 AM -
2003 Dodge Ram 2500 4x4
By drhoades3862 in forum Vehicles For Sale / TradeReplies: 0Last Post: 10-26-2006, 04:38 AM -
Engine retards at 2500 rpm
By Ponti-MANIac in forum General HelpReplies: 2Last Post: 10-13-2006, 10:37 AM
