Results 1 to 20 of 42
Thread: Not new member just first post.
05-24-2015, 08:54 AM #1Junior Member
- Aug 2014
- Michigan
Artic White- 2002 WS6
Hi everyone, thought I would post for my first time. have gotton alot of good ideas and info i needed for my car in the LS1 forum.
I am the origianl owner of a 2002 Artic White WS6 convertible. all origonal except wipers, turn signal housings and lamps and battery.
It has 32000 miles on it, garage kept and just driven in nice weather. wish I could direct post a pic. Even tires are original. Next thing I want to
get is the GM build # and SLP build#. I work at GM also, funny huh.
I have all papers from dealer they had for car because I asked.
Im from Michigan and glad to Intro myself.
Phil
05-24-2015, 09:37 AM #2Junior Member
- Aug 2014
- Michigan
05-24-2015, 09:41 AM #3
Hi Phil. You will be able to post pictures after your post count goes up (since you used a photobucket link, I was able to edit your picture for you). If you work at GM, you shouldn't have any problems getting the build numbers. You can call SLP and they can help you out also.
05-24-2015, 09:44 AM #4Junior Member
- Aug 2014
- Michigan
Hay, Thanks. I get buisy and can't keep up with all my other events. will get on more often. I was wondering why I was having such a hard time getting a picture posted.
05-24-2015, 03:28 PM #5
Greetings,
Beautiful arctic white
05-24-2015, 05:04 PM #6
Original tires! Might want to get those replaced ASAP!
And welcome!
Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
05-24-2015, 07:02 PM #7
Sharp ride! Welcome to the site.
05-24-2015, 08:23 PM #8Junior Member
- Aug 2014
- Michigan
05-25-2015, 03:21 AM #9
Welcome. You'll find this a great place to learn a lot about your car.
05-25-2015, 03:32 AM #10
Any plans on what you are going with for sneakers? I have my eye on the Mickey Thompson Street Comps right now.
05-25-2015, 07:26 AM #11Junior Member
- Aug 2014
- Michigan
05-25-2015, 07:31 AM #12Junior Member
- Dallas
Get you a set of GSD3s
05-26-2015, 08:58 AM #13Junior Member
- Aug 2014
- Michigan
Tires
I guess I don't really need z rated but am looking at either BFG comps or Goodyear F1 A. Balancing price and value, I don't race it I just cruse and get on it sometimes. I bought the car new and trying to keep it as original as possible so it will have the garage find aww factor. it is a cool car and to stay stock is rare. I know it would be bad ass if I put a few things into it but I would rather build one than convert this one. My wife would kill me if I altered this one. if I bought another one to build she would be fine with that.
05-26-2015, 09:02 AM #14Junior Member
- Aug 2014
- Michigan
Last years garage pic
in my garage.
05-26-2015, 10:44 AM #15Senior Member
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
I love the Gyr Eagle F1 GSD3's but be aware that they are starting to phase them out. You should still be able to get them just shy of $300.00 each. I have been happy with my Continental Extremecontact DW's at $225.00 each, the tires feel like they have more stick that the suspension/chasis does (guess what I am buying next). I had BFG Super Sport AS's the last two tire changes before, cheaper and better in the cold, but nowhere close on the smile-meter in performance.
05-26-2015, 10:49 AM #16Senior Member
- Sep 2007
- LaGrange, Indiana
Pewter- 2001 Camaro SS hard top
I'm a big fan of the Bridgestone Potenza RE760, I've had them on my car for 2 years now and will be getting them again when its time. They handle great and the are asymmetrical so they can be rotated which was a big reason I went with them. They run about $140 a tire, which is much cheaper than the good years.
Great looking T/A btw!Last edited by Shermanator86; 05-26-2015 at 10:52 AM.
05-26-2015, 10:50 AM #17Senior Member
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
I have the BFG KDWs after using nittos for years. Nitto only comes in drag radials for the size wheels I have now. The car is just a cruiser but KDWs do just fine for my application and look pretty good.
05-26-2015, 11:42 AM #18Senior Member
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
2000 Black TA M6 - LT's, ORY, UMI Short Stick, TT2's, Drilled/Slotted Rotors, Braided Lines, and Tuned by Vengeance
SCCA and Car Show Approved
06 Quad Cab HHHHemi - Sold
97 Camaro - Sold
05-26-2015, 12:09 PM #19Senior Member
- Aug 2007
- Greensboro, NC
Yes it is
05-26-2015, 01:36 PM #20Junior Member
- Aug 2014
- Michigan
I will definitely do some more homework, thanks for the tips and advice. Its a tough decision because once done its done.
Last year I replaced my front turn signal housings because they cracked. Because of a post on here I was able to convert to led bulbs and a electronic/manual relay and didn't have to hack wires. Works great.
New member/First post
By tnman in forum Member's RidesReplies: 3Last Post: 11-22-2010, 06:34 AM -
New Member's first post...
By timberman00 in forum Member's RidesReplies: 3Last Post: 05-07-2006, 08:35 PM
