04-23-2006, 08:32 PM #1Member
- Oct 2005
- Houston,Texas
white- 2000 Camaro Z28
Ran my 2000 Z28 A4 at the track today
I went to the track today (Houston Race Way Park) This is with my new cut out open.
My times and speeds were
[email protected] 2.078 60ft
[email protected] 2.177 "
[email protected] 2.145 "
[email protected] 2.117 "
So my time did not change but I got 2 more miles per hour from the cut out
My old time was with about 60 degree and it was about 78-80 degrees today
Bottom line, cut out = 2 MPHMTI Clear Lid (Free Ram Air Mod Raised Air box) Larger MAF Ends,K&N Filter, SS Exhasut with cut out, rear Lower control arms,smooth bellows,[email protected] Dynoed 316 HP (Before RLCA and smooth bellows) 8.3.12 @86.86 1/8th mile 121,000 miles
04-26-2006, 12:53 AM #2Junior Member
- Feb 2006
- Orlando,FL
- 01 WS6
hey man,can you school me on this..iam a Noob..
"cut out" means to cut out that piece of metel on front of the air ram on the hood?
04-26-2006, 07:11 AM #3Member
- Oct 2005
- Houston,Texas
Its called a exhaust cut out. It goes between the cats and muffler. It has a removeable plate that will let the exhaust gases to by pass the muffler. You may loose some low end torque but from my MPH gain in the 1/4 mile (2MPH) It its a solid 15-20 HP gain
04-26-2006, 09:46 AM #4Junior Member
- Feb 2006
- Orlando,FL
- 01 WS6
oh i see...thanks...
04-26-2006, 09:58 PM #5
pull a better 60' and you will be in business!
04-27-2006, 03:49 AM #6
it seems the first time is always the fastest
04-27-2006, 06:08 PM #7Get used to tha view!
- Mar 2006
Great times.
04-27-2006, 06:25 PM #8
nice mph
05-12-2006, 08:31 PM #9Green MonkeyGuest
I actually had my car dynoed with and without the cutout. You will be pleased to know it added 11 rwhp my Z28. It also increased the rwtq, but it was minor. I would have to find the printout to let you know what that number was.
05-15-2006, 05:36 PM #10
typical results of a cutout. et doesn't change. lose 60ft to gain mph. mine did the same thing. this was one 200 n2o also. gained 11/13 on the dyno after 3000 rpms. lost .1 60ft, gained 1 mph, gained .02 et.
don't forget to post in the et listing so i can add you to the list.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
05-15-2006, 06:13 PM #11Likes twisty roads
- May 2006
- England but from TX
Light Pewter Metallic- 2K Camaro Z28
Is this with stock 3.23s or 2.73s?
Originally Posted by tx77015ls1
05-15-2006, 06:56 PM #12Member
- Oct 2005
- Houston,Texas
im not sure I think 323's
Track today!
By dethinboots in forum GTOReplies: 12Last Post: 02-12-2013, 10:05 PM -
Took the GTO to the track for the first time today
By elcameano in forum GTOReplies: 6Last Post: 11-24-2009, 11:05 PM -
went to the track today...opening day
By 2kbluws6 in forum Drag RacingReplies: 6Last Post: 04-07-2008, 03:24 PM -
took the 98 to the track today 2/18
By 98 4mula in forum Drag RacingReplies: 3Last Post: 02-18-2008, 06:20 PM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
