Results 1 to 16 of 16
04-15-2015, 08:49 AM #1Junior Member
- Apr 2015
- Beaumont, Texas
new member looking for computer and wiring harness help
i have a LS1 motor and trans. out of a 2000 firebird.. i got the stock comp. with no wiring harness... it is now in a 37 Plymouth... where do i get the computer reprogrammed to work in my 37 and where do i get a plug and run harness... i am old school carb. and need a little guidance and help with this computer stuff.any help would be greatly appreciated.... Tim
04-15-2015, 09:20 AM #2Spaz is My Mentor
Do you still have access to the Firebird or was it a junkyard/private sell?
If you can get the one that came from the car it would be your easiest route.
Painless Performance sells wire harness kits that can be customized to your build but they are not cheap (looking around $630). I would pay for quality over hacking a harness to make it work, just my 2 cents. Plus you get exactly what you want/need.
Now for programming any dyno shop should be able to tune it, for a simple mail order tune, I strongly recommend Frost (tunedbyfrost.com). He has the best mail order tunes and IIRC can even sell you an unlock ECM.
What other ?? do you might have?
Would love to see how this project turns out. Love that body style....
04-15-2015, 09:35 AM #3Junior Member
- Apr 2015
- Beaumont, Texas
thanks i do not have the harness it was a private sell...i am using a manifold of of a truck instead of the ls1 intake because the truck pully fit between my fram... will there be a issue by usind a truck intake and injectors instead of the ls1 intake and injectors???
04-15-2015, 09:47 AM #4Spaz is My Mentor
Shouldn't be. IIRC the truck intakes bump the torque up a little. Injectors should be the same. If it's a stock motor they should be 28lbs. If they are 26lbs those were on the 99 yr.
Regarding accessories you have several choices, there are the F body LS1 style, Corvette LS1 style and then the truck style. Also LS2's will work, pretty much any GEN III/IV styles will work together. I moved my alternator from under the pwr steering pump to up on the passenger head.
here's how it looks now:
04-15-2015, 09:54 AM #5Junior Member
- Apr 2015
- Beaumont, Texas
looks great the reason i want to use the truck intake and pully is that the fit inside my frame rails also i was on ebay and they have a ac bracket that puts the ac compressor up top were you put your alternator ... it only works with the truck pully system....tune by frost i went to the web site and can't find a number guess im not looking in the right place....harness,,,,stand alone i guess ???
04-15-2015, 09:56 AM #6Junior Member
- Apr 2015
- Beaumont, Texas
cant seem to upload a picture,,,whats the process???
04-15-2015, 10:01 AM #7Junior Member
- Apr 2015
- Beaumont, Texas
yes it is a stock motor,,,,, i guess when i talk to steve at frost he will know what i don't need from the comp. also will i have to wire a check engine light in and a ob2 plug?
04-15-2015, 10:20 AM #8Spaz is My Mentor
CEL not sure but the OB2 most likely.
04-15-2015, 10:27 AM #9Junior Member
- Apr 2015
- Beaumont, Texas
thanks so much for the reply's tim
04-15-2015, 10:37 AM #10Spaz is My Mentor
It's what we are here for...
04-15-2015, 02:25 PM #11Senior Member
- Feb 2006
- Orange County, NY
You might also want to check out MSD's Atomic EFI. It will cost more but is another option for you.
04-16-2015, 02:58 AM #12
Welcome! Sounds like a very cool project.
Upload your pics to a free site like Photobucket and then simply copy and paste the [IMG] code for the pic into your post on here.
04-16-2015, 07:25 AM #13Spaz is My Mentor
He's got everything except the ecm & wire harness. The unit you're talking about would be for converting carb running car over to EFI.
Here's a system that might be what you're looking for:
EZ-EFI 2.0® GM LS Self Tuning Engine Control System - Self Tuning EZ-EFI 2.0 - EFI Systems Fuelairspark.com
04-16-2015, 10:05 AM #14Senior Member
- Feb 2006
- Orange County, NY
This is the system I am talking about. Atomic LS - Less Wire, More Performance.
04-16-2015, 11:38 AM #15Spaz is My Mentor
ahh I see, well now he has 2 options.....
04-20-2015, 01:55 PM #16
Another option is GM Performance http://www.gmperformancemotor.com/me...talog-2014.pdf check page 260 for their line of engine controllers.
Wanted: LS1 low mileage with wiring harness and computer
By IcantDo55 in forum Parts Wanted / TradeReplies: 1Last Post: 10-14-2009, 07:54 AM -
Wanted: computer,wiring harness, distributer pack for LT1
By timmytim1072 in forum Parts Wanted / TradeReplies: 5Last Post: 05-05-2009, 04:12 AM -
Wiring Harness?
By The yankster in forum General HelpReplies: 3Last Post: 02-12-2009, 03:33 PM -
ls1 computer and wiring harness
By CamaroMotorsports in forum Parts Wanted / TradeReplies: 0Last Post: 07-28-2006, 09:02 AM -
Need Ls1 wiring harness/computer...aplication doesn't matter (I think)
By Trickflowing in forum Parts Wanted / TradeReplies: 2Last Post: 03-04-2006, 08:54 PM
