    Jun 2014
    Connecticut
    99 Trans Am WS6
    Window motor help!
    I'm replacing the window motors in my 99 bird. Just curious if anyone has a template that I could print to show where to drill the holes?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Window motor help!
    I've never heard of having to drill new holes in a door when replacing window motors.
    Greensboro, NC
    2002 Trans Am WS6 M6
    The rivets that hold the window motor in place are not easily accessible. Alot of people drill holes to make them easier to get to. Once the panel goes back on you never know the holes are there. Did it on both my doors.
    As for a template I've never seen one. Just kind of eyeballed it.
    Orlando, FL
    Mean Black
    As raynor said you can easily feel and look for where the rivets are. Use a bigger drill bit so you have some space to reach the rivet in case you don't hit it dead on. There is no need for the holes to be dead on. Once you can see the rivets use a bit that is big enough to slowly eat away the rivet head. The use a punch or screwdriver and tap the rivet in with a hammer. Once you tap all three rivets out the motor should be easy to remove. Use the supplied screw and bolts from the new motor and install. I decided to go to the home depot and get some nylon nuts that match the new screws in the case the bolt/nuts get loose with vibration.
    Jun 2014
    Connecticut
    99 Trans Am WS6
    Thanks I was able to replace them. Found a pic on Google with measurements. I used a pilot bit then a step up but to drill the holes. Come to find out there was no rivets, they were screwed on with a nut but we're the original delco motors
    Aug 2000
    Indy
    Never seen that before but I did put in threaded rivets on my second wm replacement on the Z/28.
    04 C5 A4 Torch Red - sold
    2009 CTS4 Ice Black - sold
    2013 1500 Silverado Z71 - sold
    02 Z/28 M6 Onyx Black All Options - Sold
    2014 Caddy CTS4 - DD
    2016 Silverado 2500HD
    2020 Caddy XT6
    2020 2SS Vert
  1. Window Motor
    By new2dgame in forum General Help
    Last Post: 06-22-2010, 12:34 AM
  2. need help with window motor
    By 01pewterZ in forum General Help
    Last Post: 12-17-2007, 11:10 PM
  3. Window Motor
    By NewLS1 in forum General Help
    Last Post: 12-17-2007, 03:53 PM
  4. Window Motor Mod??
    By CamaroFan71 in forum General Help
    Last Post: 10-12-2006, 07:36 PM
