Results 1 to 11 of 11
Thread: BMR tunnel brace
04-10-2015, 09:38 PM #1Member
- Nov 2014
- near Fort Hood, TX
blue- 2002 Trans Am
BMR tunnel brace
does the BMR tunnel brace help any? worth getting?
ASh
- - - Updated - - -
ASh
04-11-2015, 02:06 AM #2
You will not notice a difference imo. Subframe connectors are what tighten up the car and, if you have 3 point SFC's, then the tunnel brace acts as a bridge between the two sides. Honestly, lots of guys just remove the tunnel brace for additional exhaust clearance although it does make for a simple pseudo drive shaft safety loop. On our car, we have the tunnel mount torque arm, so the tunnel brace mounts the front of the torque arm and also the safety loop.
04-11-2015, 02:29 AM #3Spaz is My Mentor
BMR tunnel brace
only aftermarket tunnel brace I would recommend is one with a driver saftey loop
6.0L Block - Forged 403ci
, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
04-11-2015, 09:52 AM #4Member
- Nov 2014
blue- 2002 Trans Am
2002 auto T/A custom blue, Moser 9in rear end with 31 spline axle and 3.73 gears, Diablo Sport InTune, SLP LM1 catback, SLP lid & bellow, ram air free mod, eibach pro kit springs, bilstein hd shocks, bmr rear sway bar, bmr 2pt SFC bolt on, silver checker stripes 17x9.5 C5 Vette rims.
04-11-2015, 09:54 AM #5Member
- Nov 2014
blue- 2002 Trans Am
so guessing one like this that BMR offers
ASh
04-11-2015, 02:49 PM #6
That works.
04-11-2015, 04:57 PM #7Member
- Nov 2014
blue- 2002 Trans Am
Thanks again for the help guys
ASh
04-12-2015, 04:26 AM #8
The tunnel brace bolts are awful tiny - I thought about modifying things a bit when I installed our 3 point SFC's, but in the end left them alone. Since you have to drop your driveshaft for the install, take a look at the tail stock seal on your transmission. Great time to swap it out if it is weeping at all.
04-13-2015, 10:18 AM #9Member
- Nov 2014
blue- 2002 Trans Am
I will have to remember that when I do end up getting this and installing it, what kit do you suggest to use for replacing the seal? would it not have been done when my PST driveshaft was installed?
I know when the trans go, I want to get a new built trans street friendly, but good for the track when I end up going.
also planning on doing heads/ cams down the road, either before the motor goes and needs stuff replaced or before.
I've been thinking about LT's with catted mid-pipe. My only concern right now having SLP LM1, is how loud it is going to be with LT's and catted Y-pipe, which I have thought about going with a LM2 reso, but don't know how much that will help. I have thought about just upgrading to a high flow midpipe or somehow have it dual to a high flow midpipe with stock headers into the SLP LM1 or doing the dual mid-pipe with SLP LM2
Still some time off for that to happen, got a few more suspension mods I wanting to do LCA's, adj PHB, STB, and tunnel brace safety loop. prob couple other things, but I know those for sure
all in good time I suppose just got my wheel turning and thinking about this stuff, do want to upgrade the rotors to some nicer performance ones and looking ones, probably upgrade pads at the same time.
ASh
04-14-2015, 02:58 AM #10
No kit - it is just a simple seal that you can get just about anywhere. They can be a bit tricky to tap in. I always apply a thin coat of Permatex around the outside of the seal before installing it. If it isn't weeping then you can leave it be. Could be 13 years old or so at this point if it is the original and rubber doesn't improve with age.
04-14-2015, 08:54 AM #11Member
- Nov 2014
blue- 2002 Trans Am
Help: Tunnel brace
By 2000dreambird in forum Firebird / WS6Replies: 16Last Post: 03-06-2012, 07:59 AM -
For Sale: UMI Tunnel mount brace
By cpop98ws6 in forum Parts For Sale / TradeReplies: 16Last Post: 08-18-2011, 08:11 AM -
Tunnel brace
By Teknik_SS in forum Camaro / SSReplies: 3Last Post: 11-17-2010, 08:45 AM -
Tunnel Brace - Can I leave it off
By Smokin2000 in forum Firebird / WS6Replies: 22Last Post: 09-13-2010, 10:01 PM -
SFC Install and Tunnel Brace?
By aerojt in forum Suspension and HandlingReplies: 2Last Post: 10-12-2007, 07:52 PM
