03-22-2015, 12:23 PM #1Junior Member
- Mar 2015
- NYC
black- 2006 GTO
Airbag fault 2006 gto after battery died
Battery died on my gto, when i replaced battery and started the car, i now get an airbag fault upon start up. I read that a voltage spike could trigger the warning. Is there anyway to erase the code without heaving to take it to the dealer?
thanks
03-22-2015, 04:17 PM #2
Our cars do weird stuff when battery voltage gets low. You can disconnect the battery, wait a bit and then hook it back up again to see if the code clears.
03-22-2015, 04:31 PM #3Junior Member
- Mar 2015
- NYC
black- 2006 GTO
Tired that but no luck
03-22-2015, 07:04 PM #4
how long did you leave it unhooked? OBD2 pcm's will hold a voltage for quite a while and store the code. Might want to pull the fuse too while the battery is unhooked.
03-23-2015, 07:50 AM #5Junior Member
- Mar 2015
- NYC
black- 2006 GTO
Disconnected the battery for over 30 mins just in case
03-26-2015, 03:08 AM #6
Just for fun, check your fuses and make sure that there are no secondary ground or power wires at or around the battery that may have been left disconnected or that got damaged during the battery swap.
'05 airbag fault???
By Fester801 in forum GTOReplies: 2Last Post: 03-04-2011, 08:37 PM -
Was that my fault?
By FSANE in forum Almost Anything GoesReplies: 36Last Post: 06-06-2010, 04:51 PM -
AirBag Fault reset?
By slims00ls1z28 in forum GTOReplies: 3Last Post: 06-21-2009, 05:28 PM -
Car Stereo is on LOC because battery died
By drock608 in forum General HelpReplies: 5Last Post: 04-11-2006, 11:12 PM
