Results 1 to 17 of 17
Thread: LED Daytime Running Lights???
03-05-2015, 12:25 PM #1
Has anyone found LED Replacement DRLs that work well? I have a 2001 Camaro SS looking to replace the DRL/Turn signals/Parking lamps with LEDs. I have had too many problems with the regular bulbs over heating and melting the sockets. Not sure if this is the way to go but I'm curious if anybody has had luck doing this.
03-05-2015, 12:43 PM #2Spaz is My Mentor
IIRC most use switchbacks. Not sure if you need something between them and the wire harness. Some come with it as part of the bulb.
03-05-2015, 12:48 PM #3Senior Member
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
Switchbacks are an absolute nightmare...highly recommend staying away from those.
2000 Black TA M6 - LT's, ORY, UMI Short Stick, TT2's, Drilled/Slotted Rotors, Braided Lines, and Tuned by Vengeance
SCCA and Car Show Approved
06 Quad Cab HHHHemi - Sold
97 Camaro - Sold
03-05-2015, 12:56 PM #4Spaz is My Mentor
wasn't 100% sure I knew they were used at some point
03-05-2015, 01:27 PM #5Senior Member
- May 2013
- Nashville, TN
tons of people have tried it over the years and I've only see a hand full of them work the right way. I have personally look at doing it a few times and it just doesnt seem like something I want to try lol. Easiest thing for our cars that I've seen is to swap the flasher out and then use some basic LED's and even then people still run into some misc issues from time to time. Our system just doesnt play nice with LED's in the turn signals for some reason.
03-08-2015, 06:05 AM #6
I tried 3 brands of LED bulbs and at the end of the day they will just not hold up. I believe most of the LED bulbs out there can't handle staying on constant at full power. I went back to stock bulbs. One thing I was trying to do was to maybe take off the whole and a LED panel that can be attached with a bracket. I never got to do it before i sold the car.
04-06-2015, 11:45 AM #7
Maybe we should just do this instead? (Mostly Joking)
5050 Flexible LED Strips - Flexible LED Ribbon Light, by the foot and in reels.
04-06-2015, 04:13 PM #81998 TA 130k A4, LS6 intake, TunedByFrost, Airlid, AIR and EGR delete, Borla exhaust, front Eibach lowering springs, LS6 valley cover, UMI TQ arm, UMI LCA's, UMI panhard bar, Poly engine mounts, BMR relocation brackets, Blistein HD shocks and struts, Oil catch can, Autotrix window fix.
Now I have an 2001 F150 5.4L
04-08-2015, 02:37 PM #9Senior Member
- Feb 2006
- Orange County, NY
What about using a lower wattage bulb?
04-28-2015, 08:35 PM #10
I've had the Autolumination Switchbacks for >4.5 years. I've had no issues once I got them set like I wanted. I bought brand new housings. I use the old keepitcleanwiring.com nonadjustable flashers. I also insure that I have the parking brake on when I start the car. That keeps the LEDs off while starting.
05-21-2015, 09:26 AM #11
I just got the LED bulbs from DDM today. Supposedly they are just plug and play, but it does say a resistor may be needed. If it wasn't raining here I would put them in and let you know. So, after I put them in I will update
2000 Jet Black M6 Trans Am aka Kitte:
SLP lid, cai kit, smooth bellows; Hawks HPS pads/slotted rotors; Centerforce D7X street/strip clutch; DDM HID conversion; Black w/ metal lip C5 Z06 replica 17x9.5 rims; free ram air mod; Bilstein HD shocks; LTs and ORY; Magnaflow quadtip catback
05-21-2015, 09:30 AM #12
05-21-2015, 09:45 AM #13
I upgraded my flasher when it died on me a year ago but that's good to know. I'll still let yall know what happens
05-21-2015, 10:00 AM #14
05-21-2015, 10:03 AM #15
lol yeah got tired of when one of the drl was out my turn signals not working at all so upgraded it. I have since fixed the issue with new housings and sockets
05-22-2015, 07:47 AM #16
ok put in the led drls. everything is working fine, but then like I said I have upgraded the flasher in my car though. As soon as I can figure out how to post pics I'll do that
05-22-2015, 07:58 AM #17
Question: how to disable the daytime running lights ?
By Speedy_Gonzales in forum General HelpReplies: 8Last Post: 09-08-2008, 08:42 AM -
The daytime running light
By ledesma54 in forum GTOReplies: 5Last Post: 05-12-2008, 01:24 AM -
Daytime Running Light socket gaskets
By autotrix in forum Parts For Sale / TradeReplies: 1Last Post: 04-01-2008, 06:34 PM -
Problem w/Daytime Running Lights
By 88MonteSS98WS6 in forum Firebird / WS6Replies: 6Last Post: 07-12-2007, 09:53 AM
