Results 1 to 3 of 3
    What's the matter? Johny Utah's Avatar
    Columbus Ohio
    At least its paid for.
    Looking at buying some rims and tires. Please tell me they will fit.
    I have stock rims on my 98 Z28 right now. Ok they are C4 rims they are 17x9 and 17x11 with 275 in front and 315 in rear. The offset is this. back is (+50mm offset/7.93 front is (+56mm offset with 7.4 Will they just bolt on and I can go? Or will it need some work? Thanks
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    yes, they will fit. the 88-96 C4 rims will bolt on the 93-02 f-bodies.
    Member 97PredatorTA's Avatar
    Tinley Park, IL
    '97 Trans Am
    Its possible that the rears will need a little work. Some people have problems with the 11 inch rim and 315's and have to either hammer out the wheel well a little or roll the fender.
    But most likely you wont have a problem. I have 315's on my TA and they fit fine.
    Another thing to think about is that Camaro fenders don't bulge out as far as TA fenders, so the tire might stick out past the fender a little bit.
  1. Help: Need help !! Buying tires , help . Riken raptors.
    By FirehawkM6 in forum Wheels and Tires
    Last Post: 12-02-2010, 04:04 PM
  2. help picking new tires or tires and rims
    By falseprophet79 in forum Wheels and Tires
    Last Post: 03-22-2010, 08:50 AM
  3. Wanted: Rims or Rims/Tires Combo
    By BadBlueBird* in forum Parts Wanted / Trade
    Last Post: 09-11-2008, 07:33 AM
  4. buying rims. any one heard off this company?
    By bballking_2007 in forum Appearance Section
    Last Post: 08-06-2008, 11:22 AM
  5. Replies: 1
    Last Post: 12-13-2005, 04:07 PM
