Thread: Right spark plug
01-25-2015, 06:29 PM #1
- Jan 2015
- Ft.lauderdale, fl.
Black- 2002 ws6
Right spark plug
Just found out my 2002 ws6 has a ls6 block. I put plugs for an ls1 in motor, are they the same plug?
01-25-2015, 07:04 PM #2
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
Yep same plugs unless you are running nitrous or some type of power adder.
2000 Black TA M6 - LT's, ORY, UMI Short Stick, TT2's, Drilled/Slotted Rotors, Braided Lines, and Tuned by VengeanceSCCA and Car Show Approved
06 Quad Cab HHHHemi - Sold
97 Camaro - Sold
01-26-2015, 05:14 AM #3
- Jun 2011
- Branchville, NJ
Yes they are. Use Iridium plugs and you will never need to change them again unless you foul them or upgrade your induction system. I buddy of mine put them into his Silverado truck and just replaced them with 127k on them. Almost no wear.
01-26-2015, 12:59 PM #4
Main difference between the LS1 and LS6 block is better internal venting and probably an increase in overall strength, if I recall.
01-27-2015, 11:35 AM #5
01-27-2015, 02:29 PM #6
- Jun 2011
- Branchville, NJ
Whatever plugs you use, put some anti seize on the threads and don't over tighten them. I like to use the Permatex brand.
01-28-2015, 11:37 PM #7
- Jan 2015
Black- 2002 ws6
01-28-2015, 11:40 PM #8
- Jan 2015
Black- 2002 ws6
Thanks for that info. Glad I don't have to change the seven and eight plugs, they are a pain to reach
01-29-2015, 02:59 AM #9
Couple of tips for future reference -- remove the coil packs, pop the plastic pins up that secure the cowl seal, use a 1-1/2" extension on your ratchet, and go at number 8 from under the car.
What kind of oil 5w30& spark plugs&spark plug wire
By ROMERO98Z28 in forum General HelpReplies: 20Last Post: 09-01-2009, 01:50 PM -
Spark Plug Gap
By slpgto2004 in forum GTOReplies: 5Last Post: 10-05-2007, 04:58 AM -
spark plug
By SuPeRmAn23 in forum External EngineReplies: 27Last Post: 08-21-2007, 04:54 AM -
Spark plug wire and plug!
By RYDER661 in forum General HelpReplies: 2Last Post: 03-13-2006, 09:01 PM
