Thread: posi unit
12-30-2014, 10:59 AM #1Member
- Jun 2012
- florida
posi unit
With the posi out of a car, is it possible to counter rotate the axles using pry bars or would the force be too great. I would like to check the pinion gears.
12-30-2014, 03:19 PM #2Former Mopar Man
- Jun 2011
- Branchville, NJ
Just shine a flashlight inside and you should be able to see the pinion gear without any trouble. Are you inspecting for chipped teeth or a noise ?
12-30-2014, 03:54 PM #3Member
- Jun 2012
- florida
pinion
I cant see all of the the teeth, I want to see them rotate. If they are jammed or broken I could have a real locker.
12-31-2014, 07:08 AM #4Former Mopar Man
- Jun 2011
- Branchville, NJ
With the center section out of the housing you should be able to rotate the pinion yoke without any trouble. If you have chipped ring gear teeth you have a problem but the pinion gear holds up better and if damaged will usually chip towards the pointed end. If you have any doubts about the condition of your R&P I would pull it apart or even better, upgrade to a 12 bolt, 9" or S60. Its Christmas, you deserve it. Just take the CC out of your wallet and dial the number. lol
reluctor ring on posi unit does it come off???
By kibz28 in forum DrivetrainReplies: 1Last Post: 08-18-2009, 06:16 AM -
In need of a posi unit.
By redbird555 in forum Parts Wanted / TradeReplies: 0Last Post: 03-05-2009, 01:50 AM -
Posi Unit For Sale
By Ryan Toole in forum Parts For Sale / TradeReplies: 0Last Post: 11-07-2006, 09:48 AM -
Rear End Code (which posi unit do I have)
By SSwt00SS in forum Manual TransmissionReplies: 1Last Post: 05-18-2006, 08:50 AM -
posi unit with gears
By its scot in forum Parts For Sale / TradeReplies: 3Last Post: 03-12-2006, 06:10 PM
