    Jun 2014
    Connecticut
    99 Trans Am WS6
    Inaccurate mileage do to wrong gear ratio?
    So when I bought my car it seemed to fast for what the speedo was reading. Come to find out it was off by 15 mph. Someone for some reason swapped 2:73s in at some point. I swapped the 3:42s back in and followed my dad in his truck to check speeds and its reading right again. My question is does it effect the mileage of the car. If so does anyone have any general idea by how much. Car has 91k on it now
    Arizona
    I'm not sure if you're asking if it affects the mileage mathmatically or if the gear change (cruise rpm change) affects the mileage.
    Either way, yes to both of those. With the speedo off there is no way to accurately calculate mileage with the odometer. I prefer to just use the GPS, much more accurate.
    As far as just MPG is concerned, yes, jumping from 2.73's to 3.42's will affect the overall mileage. How much is hard to say as it varies with everyones driving style and cruise speeds. With higher rpms to cruise at the same speeds, generally they sip a little more fuel.
    Sounds like someone blew up the stock rear and just threw whatever they could find out back to get the car back on the road. From a ratio perspective, the 3.42's require just over 20% more rotation at the driveshaft than the 2.73's to make the rear wheels go around one complete revolution. This is a significant difference, however, the gain in performance would outweigh any mileage concerns in my book.
    Indianapolis
    2000 WS6 6spd Hooker LT
    Maybe OP means, does the car really have 91k miles on it? Short answer is no, it has more. If it was driven 20k miles with the 2.73, and it's about 20% off on the odometer calculation, then it really has about 95k miles. About 2k miles more for every 10k driven. Roughly.
    Euclid,ohio
    1998 Z28
    true odometer miles can only be calculated if it's known at what odometer miles existed when the 2.73s' were installed and then up to when the 2.73s' were removed.
    As an examples:
    if using 2.73s',the odometer doesn't show enough of true miles,
    2.73s' were put in at 60,000,2.73s' were removed at 90,000. 30,000 with 2.73s'. 30,000 x 25% = 7500.
    91,000 + 7500 = 98,500
    if using 2.73s',the odometer shows too many true miles
    30,000 x .8 = 24,000 6,000 less 91,000 - 6000 = 85,000
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    Wow, could you imagine the engine speed at top gear with the 2.73's? For a T56, thats 1.365:1 final drive vs 1.71:1 with 3.42's in it! Wouldnt pull very hard in 6th, but stupid-crazy low rpms at cruise.
    Euclid,ohio
    1998 Z28
    1100rpm @ 62mph in 6th. Some cars with a cam can't even idle that low.
  1. Gear ratio and RPM's
    By vannatte in forum General Help
    Last Post: 08-17-2009, 08:24 PM
  2. gear ratio's
    By Team Villan in forum Drivetrain
    Last Post: 07-28-2008, 10:32 AM
  3. ?Gear ratio for LS1?
    By SycoJoe69 in forum General Help
    Last Post: 11-15-2007, 09:51 AM
  4. Gear ratio vs. take-off
    By slade8200 in forum Drivetrain
    Last Post: 04-14-2007, 05:24 PM
  5. Gear Ratio
    By enjun in forum Drivetrain
    Last Post: 01-15-2007, 12:57 AM
