    Member 01SsRacing's Avatar
    Jan 2011
    Longwood
    2001 camaro SS
    oil rear end housing and tq are
    Didn't get a great view because of lighting, But the rear end house and tq are seem to be pretty greasy and dirty. Now from what I could tell those are the only two things that looked to have grease build up any ideas? I was thinking the tail-shaft but wouldn't everything under the car be greasy?
    2001 Camaro SS, LM 1, BMR LCA, relocation brackets, BMR springs, adj panhard bar, smooth below, lid, sub-frame connectors weld on, strut brace
    2000 WS6, ls6 intake, sub-frame connectors, slp maf, slp cat delete with slp y-pipe, electric cutout, strut brace, smooth below, slp lid, bmr LCA and RLB
    A leaky pinion seal on the rear is a factory installed option on our cars. Chances are that is the issue.
    Jan 2011
    Longwood
    2001 camaro SS
    Its weird that its not all over the underside, It looks to just be on the tq arm and the whole read end housing..
    Air moving around under the car will push it all over. Any drips on the garage floor?
    Member sjgreen6's Avatar
    Dec 2009
    Mechanicsburg, PA
    Navy Blue
    2002 Trans Am WS6 Conv
    Assuming the seal is leaking while you are moving, how the air flows under your car due to the many hanging bits and pieces of exhaust and suspension, the oil will follow where the air directs it. Degrease and wipe it down really well then go for a drive and see if it returns. Look most closely at the area around the pinion seal. Bottom line, if it isn't more than a slow seepage it isn't an immediate must-do repair. Just keep an eye on it and occasionally check the level in the rear. About the time it actually starts dripping on the floor it is time to get the seal replaced.
  1. 00 camaro rear taillight housing (drivers side)
    By 70ssrag in forum Parts Wanted / Trade
    Last Post: 03-02-2009, 06:50 PM
  2. Question: For Sarge Re: Rear Wheel Housing
    By rednari in forum GTO
    Last Post: 06-11-2008, 07:13 PM
  3. t56 housing
    By Blksilvr in forum Manual Transmission
    Last Post: 04-02-2008, 03:44 PM
  4. ? about lt1 posi on a ls1 rear housing
    By FORMULA7 in forum Drivetrain
    Last Post: 02-25-2008, 07:13 PM
  5. Spohn rear sway and housing brackets, 1"
    By gd1996 in forum Parts For Sale / Trade
    Last Post: 07-22-2006, 09:20 PM
