Results 1 to 20 of 22
Thread: anyone use this catback system?
12-01-2014, 04:08 PM #1Member
- Nov 2014
- near Fort Hood, TX
blue- 2002 Trans Am
I was looking at making the T/A a little louder, I know I can mess with the Y-pipe, but I really was just trying to go with the cat-back area.
I was wondering if anyone has tried this set up? if so how is fitment. The price is not bad, but then cheap can be not good.
So just wonder if anyone has used this
98 02 Camaro Trans Am Catback Stainless Exhaust LS1 V8 SS Z28 Firehawk Bolt On | eBay
ASh
12-01-2014, 06:13 PM #2Senior Member
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
That will be a lot more than a "little" louder. Considering it has a bullet muffler its going to be as close to running straight pipes as you can get. If you have catalytic converters it'll help dampen it some.
2000 Black TA M6 - LT's, ORY, UMI Short Stick, TT2's, Drilled/Slotted Rotors, Braided Lines, and Tuned by Vengeance
SCCA and Car Show Approved
06 Quad Cab HHHHemi - Sold
97 Camaro - Sold
12-01-2014, 06:37 PM #3Member
- Nov 2014
blue- 2002 Trans Am
yes I plan on running the cats. I was reading on the true dual thread, would like to do that, but want to keep cats, because of long drives I have. This just looks clean though and might try to add my single chamber in there where the other muffler is. I just do not know if I could fit it.
There was a guy on youtube that did a single chamber muffler before the y part, so just trying to figure it out
ASh
12-01-2014, 08:33 PM #4
Is that "muffler" bolted on or welded into the exhaust? Hard to tell from the pic. Hopefully it is separate. That seems pretty cheap if new, but as long as it's mandrel bent and a good grade of stainless the only thing I'd be worried about would be how it fit.
12-01-2014, 08:44 PM #5Member
- Nov 2014
blue- 2002 Trans Am
I believe it is welded on. That was a concern for myself about the fitment.
ASh
12-01-2014, 08:47 PM #6Member
- Nov 2014
blue- 2002 Trans Am
Here is what the description says:
New Phab Catback Exhaust System w/bullet muffler
fits 1998,1999,2000,2001,2002 LS1 Camaro/Trans Am
"HUGE POWER GAINS W/ AMAZING SOUND"
This kit includes the following parts:
- Phab LS1 catback exhaust system •Fully polished stainless steel system
•Fully mandrel bent
•Beautiful TIG welds
•Includes 2 hangers for rear oem location
•Over axle system for OEM fitment and clearance
•Muffler is a 3" high flow bullet
Everything is brand new from the exhaust vendor Phabbing. No clamps are included, we prefer to weld exhaust systems because clamps look messy underneath the car. The exhaust is easy to weld because everything is slip fit. If you need clamps, we suggest stainless steel band clamps over "U" clamps. The true dual system was built on a Camaro and if you're a Trans Am owner you may need some adjusting on the tips in order to center them in your factory valance. This is a big system and ships in multiple boxes with signature confirmation required. Please message us with any questions and we will get back asap, we are in the shop 9-5 daily. If you need a qoute for custom installation please email us.
I am going to send them a email about if they guarantee fitment or not
ASh
12-01-2014, 09:07 PM #7
I'd ask what size the exhaust is diameter wise; looks like 2.5" maybe, but might be 2.25"?
12-01-2014, 11:03 PM #8Member
- Nov 2014
blue- 2002 Trans Am
Thanks, I just sent them a message about it,
I do like the part that it is Stainless Steel for sure
ASh
12-02-2014, 04:58 AM #9
I dont know about the right side of the exhaust. It looks like is on a 45' angle compared to the left side. I think it looks unparalleled.
12-02-2014, 05:05 AM #10Senior Member
- Apr 2010
- Alabama
Looks like the same thing as the slp lm1 just polished but the pipes do look smaller in diameter. I personally would just go for the SLP version especially since it comes with a warranty and they are an established company. The slp just isn't polished but it is stainless.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
12-02-2014, 05:32 AM #11Member
- Nov 2014
blue- 2002 Trans Am
Thanks guys for the input
ASh
12-02-2014, 05:46 AM #12Member
- Nov 2014
blue- 2002 Trans Am
12-02-2014, 05:47 AM #13Senior Member
- May 2013
- Nashville, TN
I noticed that as well...they should exit the same way on both sides but that one looks like its pointed too far out...
I also noticed that you'll probably have to buy new tips because it doesnt look like that gives you enough length to exit out the back bumper.
Here's a picture of the same system with corsa clone tips and as you can see, the passenger side is not flush or parallel with the drivers side...not sure if its just the pictures or a design flaw, but it does not look like it is fabbed up correctly. Im sure its nothing a little flexing couldnt fix, but it doesnt look right to me...
12-02-2014, 05:56 AM #14
Looks like a copy of the old loud mouth SLP exhaust systems to me.
12-02-2014, 06:34 AM #15
12-02-2014, 06:52 AM #16Member
- Nov 2014
blue- 2002 Trans Am
I ran LM1s on my 04 mach with a o/r h-pipe and yes very very loud, lol also on my 13 GT I had ghost cams with cat and muffler delete on,
for what i'm looking for, I believe being catted and running LM1s will be how loud I am wanting IMO, if not the SLP makes it so I can change out to the LM2 if need be which I like that option.
Thank you guys, y'all have be a pleasure to deal with,
ASh
12-02-2014, 06:52 AM #17Senior Member
- Apr 2010
- Alabama
It is a matter of opinion on what is obnoxious Jon. I never found the LM1 when I had to obnoxious even with long tube headers on. I only got rid of it because it would hold me back on my power levels and needed to go true duals. To the OP here is a sound clip of what my car sounded like with the LM1 with long tube headers and high flow cats on a 3" y-pipe. Whatever your choice is I would do a lot of research. The best way to know what you would like is to listen in person but that isn't always possible. Finding as much of sound clips for different combinations is the closest you can get without being there in person to determine what you like best.
12-02-2014, 06:59 AM #18
I have 1-7/8" LT's, no cats and the LM II. Now with the procharger installed, it is even louder. I can't tell you how many people have rolled up their windows when close to me when I'm just cruising around. It's 100x louder when I get on it. Couldn't imagine having it be even louder.
12-02-2014, 07:51 AM #19
Ash, I ran the loud mouth 1 and 2 on a 4th gen with stock manifolds and cats. You are right, the nice thing about the SLP setup is that you can swap out the muffler to suit your sound level. I found the Loud Mouth 2 very quiet with the manifolds and cats, with just a slight rumble but nothing crazy, no drone or anything of that nature.
I currently run a 4" mufflex with a magnaflow race muffler, with long tube headers and no cats. It's like Jon described. It's so friggin loud I can't stand it anymore. My wife drives that car daily and she's tired of it as well. I can literally hear her coming home from about 3-4 miles away when she's putting through the neighborhood at 35 mph. You can scare people with it, it's just flat out loud. I will admit it sounds sweet at full song, but anything else is just annoying.
12-02-2014, 09:28 AM #20Member
- Nov 2014
blue- 2002 Trans Am
Road trip?! **GMMG Catback system FS** $400
By Damian in forum Parts For Sale / TradeReplies: 2Last Post: 05-14-2010, 05:24 PM -
Borla catback exhaust system (trade)
By sk8ters501 in forum Parts For Sale / TradeReplies: 10Last Post: 05-24-2007, 08:09 AM -
Whats that catback exhaust system
By rebel ls1 in forum External EngineReplies: 4Last Post: 04-07-2007, 12:22 PM -
LT1 Dynomax 'Catback' system
By Zapper2003 in forum Parts ReviewReplies: 2Last Post: 03-10-2007, 05:53 AM -
Does anyone on here have Lt's and a catback exhaust system?
By coupe00 in forum Camaro / SSReplies: 17Last Post: 02-06-2007, 09:15 AM
